[postgis-users] Google Mercator and PostGIS under Ubuntu
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Wed Nov 19 11:06:34 PST 2008
I am just guessing, but why don't you try to install a fresh PostGIS
enabled db in the Ubuntu machine, perhaps something in the process of
"restore" was not compatible, and hosed your translation.
HTH,
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Frens
Sent: Wednesday, November 19, 2008 1:47 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Google Mercator and PostGIS under Ubuntu
I am using PostGIS for a project quite succesfully until recently I
tried
moving applications from my Windows based development environment to a
Ubuntu based test / demo environment. The postgis versions etc. are
exactly
the same: "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21
Dec
2007" USE_STATS". The database used on the Ubuntu machine is a restore
of a
backup from the windows machine. (the database is an open street map db
for
NL).
How ever I get some weird behaviour from the translate function on the
Ubuntu machine. For instance if I execute the following query:
SELECT ST_AsEWKT(
	ST_transform(
		ST_transform(
			GeomFromText(
				'POINT(5.167485 52.271499)',
				4326
			900913
		4326
on my Windows machine I get: "SRID=4326;POINT(5.16748499999999
52.271499)".
Which is what I expect. However, when I execute the exact same query on
my
Ubuntu machine (with the same postgis / postgres / etc versions) I get:
"SRID=4326;POINT(8.10187206703149e-07 8.19541802859524e-06)". The only
qlue
I have is that I get this warning: WARNING:  transform: -38 (failed to
load
NAD27-83 correction file).
So far googling didn't pay off... Anyone got some ideas?
P.S. 900913 is the SRID I use for the Google projection system, with the
following data in spatial_ref_sys:
srtext =
"PROJCS["Google Mercator",GEOGCS["WGS 84",DATUM["World Geodetic System
1984",SPHEROID["WGS
84",6378137,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]
,PROJECTION["Mercator_2SP"],PARAMETER["standard_parallel_1",0],PARAMETER
["central_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_nor
thing",0],UNIT["Meter",1],EXTENSION["PROJ4","+proj=merc
+a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0
+units=m
+nadgrids=@null +wktext  +no_defs"]]"
proj4text =
"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +wktext  +no_defs"
View this message in context:
http://www.nabble.com/Google-Mercator-and-PostGIS-under-Ubuntu-tp2058529
5p20585295.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
