[postgis-users] PostGIS 1.3.4 RC3 released
Paul Ramsey pramsey at cleverelephant.ca
Fri Nov 21 08:42:30 PST 2008
Tim, what did the diff file look like?
tmp/pgis_reg_15519/test_38_diff
P
On Fri, Nov 21, 2008 at 5:50 AM, Tim Bowden <tim.bowden at westnet.com.au> wrote:
> On Fri, 2008-11-21 at 12:25 +0000, Mark Cave-Ayland wrote:
>> Tim Bowden wrote:
>> > On Fri, 2008-11-21 at 00:42 +0900, Tim Bowden wrote:
>> >> Debian etch, AMD64 dual core
>> >> gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
>> >> postgresql 8.1.15
>> >> postgis 1.3.4rc3
>> >> geos 2.2.3, 3.0.3 & 3.1 all make and install fine.  Tested all with
>> >> importing a shp file using shp2psql no probs.
>> > Rather postgis 1.3.4rc3 makes and installs fine with each geos.  Too
>> > late at night.
>> > Regards,
>> > Tim
>> Thanks Tim. One quick thing to check is whether "make check" completes
>> with no failures on all of the above, as this is a good indicator of
>> whether things are working.
>> Incidentally I submitted some patches for GEOS 2.2 branch, so at least
>> now I have a way of testing them against my system here.
> postgis 1.3.4rc3 with:
> geos 2.2.3 make check no failures:
> Run tests: 38
> Failed: 0
> geos 3.0.3 make check no failures:
> Run tests: 39
> Failed: 0
> geos 1.3 make check resulted in 1 fail:
> regress_ogc_prep. failed (diff expected
> obtained: /tmp/pgis_reg_15519/test_38_diff)
> Run tests: 40
> Failed: 1
> Regards,
> Tim
>> ATB,
>> Mark.
> Experience is that marvelous thing that enables you recognize a mistake
> when you make it again.
> postgis-users mailing list
