[postgis-users] PostGIS 1.3.4 RC3 released
Tim Bowden
tim.bowden at westnet.com.au
Fri Nov 21 16:36:37 PST 2008
On Fri, 2008-11-21 at 08:42 -0800, Paul Ramsey wrote:
> Tim, what did the diff file look like?
Attached.
Regards,
Tim
> tmp/pgis_reg_15519/test_38_diff
> P
> On Fri, Nov 21, 2008 at 5:50 AM, Tim Bowden <tim.bowden at westnet.com.au> wrote:
> > On Fri, 2008-11-21 at 12:25 +0000, Mark Cave-Ayland wrote:
> >> Tim Bowden wrote:
> >> > On Fri, 2008-11-21 at 00:42 +0900, Tim Bowden wrote:
> >> >> Debian etch, AMD64 dual core
> >> >> gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
> >> >> postgresql 8.1.15
> >> >> postgis 1.3.4rc3
> >> >> geos 2.2.3, 3.0.3 & 3.1 all make and install fine. Tested all with
> >> >> importing a shp file using shp2psql no probs.
> >> > Rather postgis 1.3.4rc3 makes and installs fine with each geos. Too
> >> > late at night.
> >> > Regards,
> >> > Tim
> >> Thanks Tim. One quick thing to check is whether "make check" completes
> >> with no failures on all of the above, as this is a good indicator of
> >> whether things are working.
> >> Incidentally I submitted some patches for GEOS 2.2 branch, so at least
> >> now I have a way of testing them against my system here.
> > postgis 1.3.4rc3 with:
> > geos 2.2.3 make check no failures:
> > Run tests: 38
> > Failed: 0
> > geos 3.0.3 make check no failures:
> > Run tests: 39
> > Failed: 0
> > geos 1.3 make check resulted in 1 fail:
> > regress_ogc_prep. failed (diff expected
> > obtained: /tmp/pgis_reg_15519/test_38_diff)
> > Run tests: 40
> > Failed: 1
> > Regards,
> > Tim
> >> ATB,
> >> Mark.
> > Experience is that marvelous thing that enables you recognize a mistake
> > when you make it again.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
1,151c1,33
< intersects099|t
< intersects100|t
< intersects101|t
< intersects102|f
< intersects103|t
< intersects104|f
< contains099|t
< contains100|t
< contains101|f
< contains102|f
< contains103|f
< contains104|f
< covers099|t
< covers100|t
< covers101|t
< covers102|f
< covers103|t
< covers104|f
< containsproperly099|t
< containsproperly100|t
< containsproperly101|f
< containsproperly102|f
< containsproperly103|f
< containsproperly104|f
< intersects105|t
< intersects105|t
< intersects105|t
< intersects106|t
< intersects106|t
< intersects106|t
< intersects107|f
< intersects107|f
< intersects107|f
< intersects108|f
< intersects108|f
< intersects108|f
< contains105|t
< contains105|t
< contains105|t
< contains106|f
< contains106|f
< contains106|f
< contains107|f
< contains107|f
< contains107|f
< contains108|f
< contains108|f
< contains108|f
< containsproperly105|t
< containsproperly106|f
< containsproperly107|f
< containsproperly108|f
< covers105|t
< covers105|t
< covers105|t
< covers106|f
< covers106|f
< covers106|f
< covers107|f
< covers107|f
< covers107|f
< covers108|f
< covers108|f
< covers108|f
< intersects200|t|t
< intersects201|t|t
< intersects202|t|t
< intersects203|t|t
< intersects204|f|f
< intersects205|t|t
< intersects206|t|t
< intersects207|t|t
< intersects208|t|t
< intersects209|f|f
< contains200|t|f
< contains201|t|f
< contains202|t|f
< contains203|f|f
< contains204|f|f
< contains205|t|f
< contains206|t|f
< contains207|t|f
< contains208|f|f
< contains209|f|f
< containsproperly200|t|f
< containsproperly201|t|f
< containsproperly202|f|f
< containsproperly203|f|f
< containsproperly204|f|f
< containsproperly205|t|f
< containsproperly206|t|f
< containsproperly207|f|f
< containsproperly208|f|f
< containsproperly209|f|f
< covers200|t|f
< covers201|t|f
< covers202|t|f
< covers203|f|f
< covers204|f|f
< covers205|t|f
< covers206|t|f
< covers207|t|f
< covers208|f|f
< covers209|f|f
< types100|t|f|t|f|t|t|t|f
< types101|t|f|t|f|t|t|t|f
< types102|t|f|t|f|t|t|t|f
< types103|f|f|f|f|f|f|f|f
< types104|f|f|f|f|f|f|f|f
< types105|f|f|f|f|f|f|f|f
< types106|t|t|t|t|t|t|t|t
< types107|t|t|t|t|t|t|t|t
< types108|t|t|t|t|t|t|t|t
< types109|t|t|t|t|t|t|f|f
< types110|t|t|t|t|t|t|f|f
< types111|t|t|t|t|t|t|f|f
< types112|f|f|t|f|t|t|f|f
< types113|f|f|t|f|t|t|f|f
< types114|f|f|t|f|t|t|f|f
< intersects310|t
< intersects310|t
< intersects310|t
< intersects311|t
< intersects311|t
< intersects311|t
< contains310|t
< contains310|t
< contains310|t
< contains311|f
< contains311|f
< contains311|f
< containsproperly310|f
< containsproperly311|f
< covers310|t
< covers310|t
< covers310|t
< covers311|t
< covers311|t
< covers311|t
> ERROR: syntax error at or near "," at character 124
> ERROR: syntax error at or near "," at character 120
> ERROR: syntax error at or near "," at character 116
> ERROR: syntax error at or near "," at character 136
> ERROR: syntax error at or near "," at character 225
> ERROR: syntax error at or near "," at character 221
> ERROR: syntax error at or near "," at character 237
> ERROR: syntax error at or near "," at character 217
> ERROR: syntax error at or near "," at character 205
> ERROR: syntax error at or near "," at character 195
> ERROR: syntax error at or near "," at character 235
> ERROR: syntax error at or near "," at character 185
> ERROR: syntax error at or near "," at character 466
> ERROR: syntax error at or near "," at character 130
> ERROR: syntax error at or near "," at character 132
> ERROR: syntax error at or near "," at character 126
> ERROR: syntax error at or near "," at character 128
> ERROR: syntax error at or near "," at character 142
> ERROR: syntax error at or near "," at character 144
> ERROR: syntax error at or near "," at character 122
