[postgis-users] PostGIS 1.3.4 RC3 released
Paul Ramsey pramsey at cleverelephant.ca
Fri Nov 21 19:43:34 PST 2008
Thanks. I guess it's possible the syntax in my regression doesn't
agree with pgsql 8.1... something to check.
P
On Fri, Nov 21, 2008 at 4:36 PM, Tim Bowden <tim.bowden at westnet.com.au> wrote:
> On Fri, 2008-11-21 at 08:42 -0800, Paul Ramsey wrote:
>> Tim, what did the diff file look like?
> Attached.
> Regards,
> Tim
>> tmp/pgis_reg_15519/test_38_diff
>> P
>> On Fri, Nov 21, 2008 at 5:50 AM, Tim Bowden <tim.bowden at westnet.com.au> wrote:
>> > On Fri, 2008-11-21 at 12:25 +0000, Mark Cave-Ayland wrote:
>> >> Tim Bowden wrote:
>> >> > On Fri, 2008-11-21 at 00:42 +0900, Tim Bowden wrote:
>> >> >> Debian etch, AMD64 dual core
>> >> >> gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
>> >> >> postgresql 8.1.15
>> >> >> postgis 1.3.4rc3
>> >> >> geos 2.2.3, 3.0.3 & 3.1 all make and install fine.  Tested all with
>> >> >> importing a shp file using shp2psql no probs.
>> >> > Rather postgis 1.3.4rc3 makes and installs fine with each geos.  Too
>> >> > late at night.
>> >> > Regards,
>> >> > Tim
>> >> Thanks Tim. One quick thing to check is whether "make check" completes
>> >> with no failures on all of the above, as this is a good indicator of
>> >> whether things are working.
>> >> Incidentally I submitted some patches for GEOS 2.2 branch, so at least
>> >> now I have a way of testing them against my system here.
>> > postgis 1.3.4rc3 with:
>> > geos 2.2.3 make check no failures:
>> > Run tests: 38
>> > Failed: 0
>> > geos 3.0.3 make check no failures:
>> > Run tests: 39
>> > Failed: 0
>> > geos 1.3 make check resulted in 1 fail:
>> > regress_ogc_prep. failed (diff expected
>> > obtained: /tmp/pgis_reg_15519/test_38_diff)
>> > Run tests: 40
>> > Failed: 1
>> > Regards,
>> > Tim
>> >> ATB,
>> >> Mark.
>> > Experience is that marvelous thing that enables you recognize a mistake
>> > when you make it again.
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
