[postgis-users] simplify a linestring to n points
Martin Davis mbdavis at refractions.net
Mon Nov 24 09:28:44 PST 2008
Nope.  You might be able to repeatedly simplify and check for when you
pass your point limit.
Interesting question though... it should be straightforward to adapt the
DP algorithm to incorporate # points as an exit criteria.
richard -rw- weinberger wrote:
> hi list!
> does postgis provide a method to reduce/simplify a linestring to a
> specific number of points?
> i'm aware of st_simplify() but i have to set an lower limit.
> thanks,
> //richard
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
