[postgis-users] Get concave hull from an array of longitude inlatitude points
Martin Davis
mbdavis at refractions.net
Mon Nov 24 11:37:19 PST 2008
Yeah, I saw that too. Unfortunately the algorithm is only available by
email, and is implemented in Mathematica. It also sounds somewhat
complex.
But I guess this sort of answers my question - there are algorithms
which people have called "concave hull", and they produce concave
polygons from sets of points in some kind of way. I don't think there's
any consensus on what algorithm to use, though.
One interesting approach is here:
http://grass.osgeo.org/wiki/Create_concave_hull
In any case, obviously this isn't in PostGIS right now.
Obe, Regina wrote:
> Evidentally its this thing
> http://ubicomp.algoritmi.uminho.pt/local/concavehull.html
> So I guess basically you take the boundary and you get rid of points
> that have points sitting to the right/left/top/or bottom of it and then
> you form a polygon from the remaining points.
> Well at least that is what it seems like to me visually. Just not
> quite sure how to program such a thing without writing yuck procedural
> code.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net on behalf of
> Martin Davis
> Sent: Mon 11/24/2008 1:58 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Get concave hull from an array of
> What's a concave hull?
> Ales Kecman wrote:
> > Hi!
> > I'm new to Postgis and would really like to get some help on getting a
> > concave hull from an array of points.
> > For example:
> > I have an array of points - longitude and latitude of buildings in
> > particular area in the city. I already managed to get a convex hull
> > polygon from this array of points, but this is not really helpful.
> > What I'm trying to get is some kind of concave hull polygon from an
> > array of points, which I would further like to use in Google Earth kml
> > file.
> > Thanks.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
Martin Davis
(250) 383-3022
