[postgis-users] Get concave hull from an array of longitudeinlatitude points
Obe, Regina
robe.dnd at cityofboston.gov
Mon Nov 24 11:24:32 PST 2008
Are scratch that thought. That's not right either.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Obe, Regina
Sent: Mon 11/24/2008 2:16 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Get concave hull from an array of longitudeinlatitude points
Evidentally its this thing
http://ubicomp.algoritmi.uminho.pt/local/concavehull.html
So I guess basically you take the boundary and you get rid of points
that have points sitting to the right/left/top/or bottom of it and then
you form a polygon from the remaining points.
Well at least that is what it seems like to me visually. Just not quite sure how to program such a thing without writing yuck procedural code.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Martin Davis
Sent: Mon 11/24/2008 1:58 PM
Subject: Re: [postgis-users] Get concave hull from an array of longitude inlatitude points
What's a concave hull?
Ales Kecman wrote:
> Hi!
> I'm new to Postgis and would really like to get some help on getting a
> concave hull from an array of points.
> For example:
> I have an array of points - longitude and latitude of buildings in
> particular area in the city. I already managed to get a convex hull
> polygon from this array of points, but this is not really helpful.
> What I'm trying to get is some kind of concave hull polygon from an
> array of points, which I would further like to use in Google Earth kml
> file.
> Thanks.
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081124/3ec585b9/attachment.html>
