[postgis-users] return boundary
Martin Davis mbdavis at refractions.net
Mon Nov 24 17:15:08 PST 2008
They're similar, but I'm not sure they're 100% the same in all cases.
In the "mainland plus islands" case it seems there is a requirement to
ensure that all the input polygons are contained in the result.  The
concave hull concept as presented is based purely on a point set, and
thus might not necessarily cover all of the input polygons.
Also, the concave hull is defined by a distance tolerance.  In a
situation with islands both very close and very far, it might be hard to
find a distance value which would include all islands but not compromise
the shape of the main polygon too much.
Of course it all depends on the data - there's probably lots of cases
where both would produce similar results.
Tim Bowden wrote:
> On Mon, 2008-11-24 at 11:45 -0500, Travis Kirstine wrote:
>> I don't think that the geom union would in combination with the
>> boundary would attach the island to the mainland.  I don't think that
>> there is a simple answer to my problem but I have attached a pic to
>> help illustrate what I'm trying to accomplish.
>> Regards
> Looking at that image seems to me it's just another case of what Regina
> pointed to (http://ubicomp.algoritmi.uminho.pt/local/concavehull.html)
> in the concave hull thread.
> Regards,
> Tim
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
