[postgis-users] PostGIS 1.3.4 Released
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 24 22:30:36 PST 2008
After a lengthy development and testing process, it is with some
trepidation that we bring PostGIS 1.3.4 out into a harsh and
unforgiving world.
http://postgis.refractions.net/download/postgis-1.3.4.tar.gz
- New Features
- Add new ST_AsGeoJSON() function to allow conversion of
geometries to GeoJSON format within the database. (Olivier Courtin)
- Add forthcoming PostgreSQL 8.4 support
(Paul Ramsey, Mark Cave-Ayland)
- Improved CSS for PostGIS documentation (Dane Springmeyer)
- Inclusion of new "postgis_comments.sql" file to enable detailed
function comments to be installed for PostGIS functions. This
attaches a description and associated parameter information
to each function so that this information is available directly
within psql/pgAdmin (Regina Obe)
- Enhancements and Bug Fixes
- General documentation improvements (Regina Obe, Kevin Neufield)
- Improve PiP code by removing substantial memory leaks and adding
multi-polygon support (Paul Ramsey)
- Improve GiST consistent performance (Paul Ramsey)
- GBT#20: Improved algorithm for ST_DWithin (Paul Ramsey)
- GBT#21: locate_along_measure: wrong values, invalid data
(Mark Cave-Ayland)
- GBT#23: wrong proj4text in spatial_ref_sys for SRID 31300 and 31370
(Paul Ramsey)
- GBT#43: Heap over-read in compute_geometry_stats() (Landon Fuller)
- GBT#44: ST_Relate(geom,geom,pattern) is case sensitive (Paul Ramsey)
- GBT#45: bug in postgis_restore.pl - not passing options to createdb
(Paul Ramsey)
- GBT#58: bounding box of circular string is incorrect (Mark Leslie)
- GBT#65: ST_AsGML kills the backend when fed a CIRCULAR STRING
(Mark Cave-Ayland)
- GBT#66: ST_Dump kills backend when fed CIRCULAR STRING
(Mark Cave-Ayland)
- GBT#68: ST_Shift_Longitude doesn't work with MULTIPOINT
(Mark Cave-Ayland)
- GBT#69: ST_Translate crashes when fed circular string
(Mark Cave-Ayland)
- GBT#70: ST_NPoints Crashes with Curves (Mark Cave-Ayland)
