[postgis-users] degree vs. metric projection performance?
    Pedro Doria Meunier
    pdoria at netmadeira.com
    Tue Nov 25 05:21:54 PST 2008
Hi David,
Edgar Soldin wrote a very useful plugin that can help you with that:
http://soldin.de/about/2004-jump_plugins/
CTS extension.
You just have to put the correct values into $OJHOME/lib/ext/cs.conf
You can get those out of spatial_ref_sys table from your postgis-enabled
database (srtext column)
With this you can work in metric-based projection and after your done
re-project it back to wgs84 and save it in whatever format you use.
HTH,
Pedro Doria Meunier.
Davi Pires wrote:
> Hi all,
> I am developing an application that uses google maps as a front-end
> and postgis in the backend. Currently, we are using google mercator
> projection (SRID = 4326) for all geometries in the database. But,
> since we perform lots of geometric operations with these objects
> within the database, I am concerned about performance issues.
> Wouldn't it be better if instead of a mercator projection, we stored
> all information in metric-based values?
> If so, is there any metric-based projection that works in any part of the world?
> Thanks for any help.
> Davi Pires
