R: [postgis-users] degree vs. metric projection performance?
P.Rizzi Ag.Mobilità Ambiente
paolo.rizzi at ama-mi.it
Wed Nov 26 06:18:29 PST 2008
Following is what I found out about this matter.
Mind you: I did _not_ tested it very well...!!!
Bye
Paolo Rizzi
.) Since version 6.15, in the EPSG database exists a new SRID:
3785
that should be used to project coordinates like GoogleMaps, VirtualHearth, etc.
All those systems store, input and output coordinates as WGS84 (SRID:4326),
but to draw maps they use a specifical projection that was, in the end,
received by EPSG.
To add this CRS to PostGIS, you can use the following SQL fragment:
--- To insert into spatial_ref_sys, if missing, the CSR:
--- EPSG 3785 : Popular Visualisation CRS / Mercator
--- If already present, no change is done.
INSERT INTO "spatial_ref_sys"
select
3785 as srid,
'EPSG' as auth_name,
3785 as auth_srid,
'PROJCS["Popular Visualisation CRS / Mercator", GEOGCS["Popular Visualisation CRS", DATUM["Popular Visualisation Datum", SPHEROID["Popular Visualisation Sphere", 6378137, 0, AUTHORITY["EPSG",7059]], TOWGS84[0, 0, 0, 0, 0, 0, 0], AUTHORITY["EPSG",6055]], PRIMEM["Greenwich", 0, AUTHORITY["EPSG", "8901"]], UNIT["degree", 0.0174532925199433, AUTHORITY["EPSG", "9102"]], AXIS["E", EAST], AXIS["N", NORTH], AUTHORITY["EPSG",4055]], PROJECTION["Mercator"], PARAMETER["False_Easting", 0], PARAMETER["False_Northing", 0], PARAMETER["Central_Meridian", 0], PARAMETER["Latitude_of_origin", 0], UNIT["metre", 1, AUTHORITY["EPSG", "9001"]], AXIS["East", EAST], AXIS["North", NORTH], AUTHORITY["EPSG",3785]]'
as srtext,
'+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs'
as proj4text
where not exists(select 1 from "spatial_ref_sys" where "srid"=3785);
.) See also:
http://www.iter.dk/post/2008/05/SphericalWeb-Mercator-EPSG-code-3785.aspx
http://spatialreference.org/ref/user/google-projection/
http://forums.oracle.com/forums/thread.jspa?messageID=2684150&tstart=0
(for Oracle)
> -----Messaggio originale-----
> Da: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Per
> conto di Obe,
> Regina
> Inviato: mercoledì 26 novembre 2008 15.06
> A: PostGIS Users Discussion
> Oggetto: RE: [postgis-users] degree vs. metric projection performance?
> > By the way, are the Google Mercator and WGS84 systems equivalent
> No they aren't. I think Google is a mercator meter
> projection (not good
> for measurement though but more or less good for
> presentation) and they
> use WGS84 datum when accepting data. I think it actually has an
> official SRID (could be wrong)
> that is EPSG:900913
> and proj4 looks like this
> +x_0=0.0 +y_0=0
> People usually plot WGS84 longlat (4326) on Google Maps, thus the
> confusion.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
