[postgis-users] degree vs. metric projection performance?
Obe, Regina
robe.dnd at cityofboston.gov
Wed Nov 26 06:35:01 PST 2008
Its not in there. The closest in there is SRID=3395 which is just
mercator.
+proj=merc +lon_0=0 +k=1.000000 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84
+units=m +no_defs
I'm not clear the differences.
I suppose we should add it since for example looking at the OpenLayers
list - a lot of people use it
and it seems to be a defacto id if not an official EPSG code. though
whether to use 900913 or 3785. Neither of which are in the
spatial_ref_sys to my knowledge.
I think Google Mercator does go by multiple SRIDs, so maybe its not
really in the standard yet. I'm actually not quite sure about that.
Here are a couple of threads
http://crschmidt.net/blog/243/google-projection-900913/
http://lists.gpsdrivers.org/pipermail/gpsdrive/2008-March/000855.html
According to this the agreed standard is EPSG:3785 but never heard of
anyone using that SRID. Most
of the examples I have seen use 900913 so maybe the new 3785 is to cover
both Virtual Earth and Google but not sure if that quite describes both
to the letter.
http://www.sharpgis.net/post/2008/05/SphericalWeb-Mercator-EPSG-code-378
5.aspx
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Pedro Doria Meunier
Sent: Wednesday, November 26, 2008 9:11 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] degree vs. metric projection performance?
Hi Regina :)
Could you please provide the entry for the spatial_ref_sys table for
this SRID ?
Best regards,
Pedro Doria Meunier
Obe, Regina wrote:
>> By the way, are the Google Mercator and WGS84 systems equivalent
> No they aren't. I think Google is a mercator meter projection (not
good
> for measurement though but more or less good for presentation) and
they
> use WGS84 datum when accepting data. I think it actually has an
> official SRID (could be wrong)
> that is EPSG:900913
> and proj4 looks like this
> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0
> +k=1.0 +units=m +nadgrids=@null +no_defs
> People usually plot WGS84 longlat (4326) on Google Maps, thus the
> confusion.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
