[postgis-users] degree vs. metric projection performance? - Writing the answer to my own question :)
Pedro Doria Meunier pdoria at netmadeira.com
Wed Nov 26 06:27:39 PST 2008
Sorry to trouble you Regina... (blush)
I googled for it. ;-)
sql code:
INSERT INTO spatial_ref_sys (srid,auth_name,auth_srid,srtext,proj4text)
VALUES
(900913,'EPSG',900913,'PROJCS["Google Mercator", GEOGCS["WGS
84",DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0,
298.257223563,
AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",
0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
AXIS["Geodetic latitude", NORTH], AXIS["Geodetic longitude", EAST],
AUTHORITY["EPSG","4326"]], PROJECTION["Mercator (1SP)",
AUTHORITY["EPSG","9804"]], PARAMETER["semi_major", 6378137.0],
PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin",
0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor",
1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0],
UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH],
AUTHORITY["EPSG","900913"]]','+proj=merc +a=6378137 +b=6378137
+lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
+no_defs');
BR,
Pedro Doria Meunier
Pedro Doria Meunier wrote:
> Hi Regina :)
> Could you please provide the entry for the spatial_ref_sys table for
> this SRID ?
> Best regards,
> Pedro Doria Meunier
> Obe, Regina wrote:
>>>  By the way, are the Google Mercator and WGS84 systems equivalent
>> No they aren't.  I think Google is a mercator meter projection (not good
>> for measurement though but more or less good for presentation) and they
>> use WGS84 datum when accepting data.  I think it actually has an
>> official SRID (could be wrong)
>> that is EPSG:900913
>> and proj4 looks like this
>> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
>> +k=1.0 +units=m +nadgrids=@null +no_defs
>> People usually plot WGS84 longlat (4326) on Google Maps, thus the
>> confusion.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
