[postgis-users] re: lwpostgis.sql and liblwgeom.so
ROBERT HOLLINGSWORTH
reh2 at prodigy.net
Thu Oct 2 12:05:31 PDT 2008
to answer my own question (and with some advice from Chris at Refractions, thanks):
I was getting errors in loading lwpostgis.sql re: liblwgeom.so
altho I'd built and installed geos 3, I think I'd also earlier installed a 2.x version using "yum install"
so I did a yum remove geos.i386,
and redid ./configure and make and make install for the geos 3,
and referenced the correct lib dir for the geos libs in /etc/ld.so.conf,
and ran ldconfig,
redid ./configure, make, make install for postgis (actually threw in a make clean too before make),
and ran the psql -f lwpostgis.sql
and it ran without error, so now I can create tables with geometry.
this may help down the road next time someone runs lwpostgis.sql and it barfs over liblwgeom.so
Robert H.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081002/ff9f6d2f/attachment.html>
