[postgis-users] Re: Spring/Hibernate/JDBC with PostgreSQL/PostGIS types?
Sandeep Kumar Jakkaraju sandeepkumar.jakkaraju at gmail.com
Thu Oct 9 07:56:24 PDT 2008
Just curious ..........there was one article on Spatial EJB on postgis site
doesnt that suffice your need ......................
On Thu, Oct 9, 2008 at 7:07 PM, Stefan Keller <sfkeller at gmail.com> wrote:
> We had a 'breakthrough'... Here's the blog:
> http://mollusca.ch/blog/index.php/2008/10/06/grails-spatial-data-postgis
> Stefan
> 2008/10/2 Stefan Keller <sfkeller at gmail.com>:
> > It's hard to believe that we are the first and the only ones (as of now)
> > to combine Grails/Groovy/Spring/Hibernate and PostGIS - but so it seems
> to be!
> > We've now found a solution and will blog about this soon.
> > Yours, Stefan
> > 2008/9/24 Stefan Keller <sfkeller at gmail.com>:
> >> I'm stuck in using Grails/Groovy/Spring/Hibernate to access
> PostgreSQL/PostGIS.
> >> I'd like to simply sketch a class like this:
> >> class POI {
> >>    String name
> >>    Geometry java_geom  // from com.vividsolutions.jts.geom.Geometry?
> (POINT)
> >> ... and then map java_geom to 'the_geom' of type geometry/POINT (in
> PostgreSQL).
> >> I found mainly this: In the FOSS4G '07 symposium
> >> http://www.foss4g2007.org/presentations/view.php?abstract_id=118 (did
> >> reverse mapping instead of forward). In
> >> http://www.pascalalma.net/2007/03/04/entering-the-world-of-gis/ (old?)
> >> and of course HibernateSpatial (doesn't fit to Grails/Groovy/Spring?).
> >> Does anyone have experience with Spring/Hibernate+PostGIS or
> >> Grails/Groovy/Spring/Hibernate+PostGIS ?
> >> -- Stefan
> postgis-users mailing list
Thanks
Regards
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081009/44ab151f/attachment.html>
