[postgis-users] Cascaded Union Aggregate function
Paragon Corporation
lr at pcorp.us
Mon Oct 6 02:29:54 PDT 2008
Dan,
Disregard my last email except the OpenJump part. I was reading out of
order.
Thanks,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dane
Springmeyer
Sent: Monday, October 06, 2008 1:12 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Cascaded Union Aggregate function
Regina,
Okay, I've finished running your fuller test query included on the wiki.
Both of the variations on your cascade union timed the same, and
astonishingly faster that ST_Union:
SELECT ST_NPoints(upgis_cascadeunion(the_geom)) As afterpoints,
Sum(ST_NPoints(the_geom)) as beforepoints
FROM npsa;
-- 4.05 minutes
-- points before = 163612
-- points after = 1069320
SELECT ST_NPoints(ST_Union(the_geom)) As afterpoints,
FROM npsa;
--161.85 min
http://postgis.refractions.net/pipermail/postgis-devel/2008-August/003412.ht
ml
SELECT ST_NPoints(st_cascadeunion(the_geom)) As afterpoints,
FROM npsa;
-- 4.06 minutes
Dane
On Oct 5, 2008, at 10:29 AM, Paragon Corporation wrote:
Dane,
Nice to hear. I ran on your set too, but ran thru the whole thing
FROM npsa_albers
Took SELECT 259329/1000.0/60 ms => 4.322 minutes
N Points after = 163,612;
N Points Before = 1,069,320;
I was afraid to try this using the current ST_Union (you remember by chance
how long your below takes with ST_Union?)
I tried unioning the shape in OpenJump version that has the cascade union
and it took about 5 minutes.
I'll have to try that again since in all the tests
I have run OpenJump has always been faster (unfortunately where I am at the
moment, my PostgreSQL is running on server and OpenJump with shape locally,
so that may not have been a fair test). But it seems to end up with the
same number of points of 163,612.
Thanks,
Regina
_____
Springmeyer
Sent: Sunday, October 05, 2008 12:59 PM
Regina,
Great, my query now works with your amended upgis function posting.
So, here are my timing outputs for the dataset on watersheds I just sent a
reference to:
select count(*) from npsa;
--3162 records
select st_cascadeunion(the_geom) from npsa group by wholedrain;
-- 48.39 sec
select upgis_cascadeunion(the_geom) from npsa group by wholedrain;
-- 50.91 sec
select ST_Union(the_geom) from npsa group by wholedrain;
-- 2.49 minutes
select ST_Collect(the_geom) from npsa group by wholedrain;
-- 10.73 seconds
Next chance I get I'll take a look at the actual results.
Thanks!
Dane
On Oct 5, 2008, at 5:53 AM, Paragon Corporation wrote:
Dane,
Dane,
Oops sorry about that . I just posted a revised version. Can you try that
out? Thanks.
Also can you send me a sample of your data off list. I think the issue was
I was experimenting with array_append vs. st_geom_accum and I had gotten the
error you described below, but then was unable to replicate it again.
It could be the detoasting affect of st_geom_accum that Mark had described
was the difference between the two.
Thanks,
Regina
-----Original Message-----
Springmeyer
Sent: Sunday, October 05, 2008 1:47 AM
Hi Regina,
Thank you so much for the wiki posting. I've been using your code from your
august 12th email with great success, if not joy. What an amazing speed
improvement, especially for such a critical function. This was your exact
email of code I have working:
ml
I've just downloaded the new code off the wiki, but I'm getting an error of
'Unknown Geometry Type: 0'. I'll paste the whole error below in case you
have an idea what might be going on. I'm running mac 10.5 with these
details:
postgis_version
1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
PostgreSQL 8.3.3 on i386-apple-darwin9.4.0, compiled by GCC
Cheers,
Dane
-- full error:
test=# select upgis_cascadeunion(the_geom) from npsa group by wholedrain;
ERROR: Unknown geometry type: 0
CONTEXT: SQL function "upgis_dump_collect_garray" statement 1
SQL statement "SELECT
upgis_dump_collect_garray( array_append(ARRAY(SELECT $1 [s] As geom FROM
generate_series(1, $2 ) As s WHERE NOT (s = ANY( $3 )) ),
st_unite_garray(ARRAY(SELECT $1 [s] As geom FROM generate_series(1,
$2 ) As s WHERE s = ANY( $3 ) ) ) ) )"
PL/pgSQL function "st_collect_unite_garray" line 29 at assignment SQL
statement "SELECT upgis_unitecascade_garray(ARRAY(SELECT
st_collect_unite_garray( $1 [i:least(i + $2 - 1, $3 )]) As geom FROM
generate_series(1, $3 , $2 ) As i), $4 + 1, $5 , false)"
PL/pgSQL function "upgis_unitecascade_garray" line 48 at assignment
upgis_dump_collect_garray( array_append(ARRAY(SELECT $1 [ $2 [s]] As geom
FROM generate_series(1, array_upper( $2 ,1)) As s ),
upgis_unitecascade_garray(ARRAY(SELECT $1 [s] As geom FROM
generate_series(1, $3 ) As s WHERE NOT (s = ANY( $2 )) ), $4 + 1,
$5 , true) ) )"
PL/pgSQL function "upgis_unitecascade_garray" line 33 at assignment SQL
function "upgis_unitecascade_garray_sort" statement 1
On Oct 4, 2008, at 4:53 PM, Paragon Corporation wrote:
Oops sorry about that.
Just realized I had ugly spaces in the link. I've changed it. Use
this one
http://postgis.refractions.net/support/wiki/index.php?upgis_cascadeuni
on
Paragon Corporation
Sent: Saturday, October 04, 2008 7:44 PM
To: 'PostGIS Users Discussion'
Subject: [postgis-users] Cascaded Union Aggregate function
For those people who have unions to do that are slow, feel free to try
out this aggregate union function.
I haven't tested it enough for it to make it into 1.3.4, but have
included a link to the source code in the wiki. It should work just
fine on PostGIS versions 1.2.2 and above.
http://postgis.refractions.net/support/wiki/index.php?PL%2FPGSQL%20Pse
udo%20 Cascade%20Union%20Aggregate%20Function
Let me know if you run into any problems with it. It has worked well
for the samples I have used it on.
Thanks,
Regina
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081006/41ca979a/attachment.html>
