[postgis-users] Cascaded Union Aggregate function
Obe, Regina
robe.dnd at cityofboston.gov
Mon Oct 6 04:02:06 PDT 2008
Dane,
I just ran the full union set in OpenJump and it took 55 seconds.
Running your below for me with the OpenJump that contains the Cascade
Union functionality takes 30 seconds.
So don't know what was wrong with the other pc I was on. Maybe I had
too much going on or there is something flawed with the snapshot I was
using on that box (it was definitely cascade union though because the
non-cascade one has a count down and ran out of memory when trying to do
the whole set). OpenJump cascade union still wins hands down :).
I tried unioning on this same box with my PostGIS install for good
comparison and my timings for the
--69 secs
select upgis_cascadeunion(the_geom) from npsa_albers group by
wholedrain;
and
-- 61 secs
select ST_NPoints(upgis_cascadeunion(the_geom)) from npsa_albers group
by wholedrain;
I'm going to assume its a bit slower on this box because I haven't
tweaked my postgresql.conf on this machine.
Next I'll test on my linux 1.3.4 SVN install.
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Paragon Corporation
Sent: Monday, October 06, 2008 5:30 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Cascaded Union Aggregate function
Dan,
Disregard my last email except the OpenJump part. I was reading out of
order.
Thanks,
Regina
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dane
Springmeyer
Sent: Monday, October 06, 2008 1:12 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Cascaded Union Aggregate function
Regina,
Okay, I've finished running your fuller test query included on the wiki.
Both of the variations on your cascade union timed the same, and
astonishingly faster that ST_Union:
SELECT ST_NPoints(upgis_cascadeunion(the_geom)) As afterpoints,
Sum(ST_NPoints(the_geom)) as beforepoints
FROM npsa;
-- 4.05 minutes
-- points before = 163612
-- points after = 1069320
SELECT ST_NPoints(ST_Union(the_geom)) As afterpoints,
FROM npsa;
--161.85 min
http://postgis.refractions.net/pipermail/postgis-devel/2008-August/00341
2.html
SELECT ST_NPoints(st_cascadeunion(the_geom)) As afterpoints,
FROM npsa;
-- 4.06 minutes
Dane
On Oct 5, 2008, at 10:29 AM, Paragon Corporation wrote:
Dane,
Nice to hear. I ran on your set too, but ran thru the whole
thing
FROM npsa_albers
Took SELECT 259329/1000.0/60 ms => 4.322 minutes
N Points after = 163,612;
N Points Before = 1,069,320;
I was afraid to try this using the current ST_Union (you
remember by chance how long your below takes with ST_Union?)
I tried unioning the shape in OpenJump version that has the
cascade union and it took about 5 minutes.
I'll have to try that again since in all the tests
I have run OpenJump has always been faster (unfortunately where
I am at the moment, my PostgreSQL is running on server and OpenJump with
shape locally, so that may not have been a fair test). But it seems to
end up with the same number of points of 163,612.
Thanks,
Regina
Springmeyer
Sent: Sunday, October 05, 2008 12:59 PM
Regina,
Great, my query now works with your amended upgis function
posting.
So, here are my timing outputs for the dataset on watersheds I
just sent a reference to:
select count(*) from npsa;
--3162 records
select st_cascadeunion(the_geom) from npsa group by wholedrain;
-- 48.39 sec
select upgis_cascadeunion(the_geom) from npsa group by
wholedrain;
-- 50.91 sec
select ST_Union(the_geom) from npsa group by wholedrain;
-- 2.49 minutes
select ST_Collect(the_geom) from npsa group by wholedrain;
-- 10.73 seconds
Next chance I get I'll take a look at the actual results.
Thanks!
Dane
On Oct 5, 2008, at 5:53 AM, Paragon Corporation wrote:
Dane,
Dane,
Oops sorry about that . I just posted a revised
version. Can you try that
out? Thanks.
Also can you send me a sample of your data off list. I
think the issue was
I was experimenting with array_append vs. st_geom_accum
and I had gotten the
error you described below, but then was unable to
replicate it again.
It could be the detoasting affect of st_geom_accum that
Mark had described
was the difference between the two.
Thanks,
Regina
-----Original Message-----
On Behalf Of Dane
Springmeyer
Sent: Sunday, October 05, 2008 1:47 AM
function
Hi Regina,
Thank you so much for the wiki posting. I've been using
your code from your
august 12th email with great success, if not joy. What
an amazing speed
improvement, especially for such a critical function.
This was your exact
email of code I have working:
2.ht
ml
I've just downloaded the new code off the wiki, but I'm
getting an error of
'Unknown Geometry Type: 0'. I'll paste the whole error
below in case you
have an idea what might be going on. I'm running mac
10.5 with these
details:
postgis_version
1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
PostgreSQL 8.3.3 on i386-apple-darwin9.4.0, compiled by
GCC
Cheers,
Dane
-- full error:
test=# select upgis_cascadeunion(the_geom) from npsa
ERROR: Unknown geometry type: 0
CONTEXT: SQL function "upgis_dump_collect_garray"
statement 1
SQL statement "SELECT
upgis_dump_collect_garray( array_append(ARRAY(SELECT $1
[s] As geom FROM
generate_series(1, $2 ) As s WHERE NOT (s = ANY( $3 ))
st_unite_garray(ARRAY(SELECT $1 [s] As geom FROM
generate_series(1,
$2 ) As s WHERE s = ANY( $3 ) ) ) ) )"
PL/pgSQL function "st_collect_unite_garray" line 29 at
assignment SQL
statement "SELECT
upgis_unitecascade_garray(ARRAY(SELECT
st_collect_unite_garray( $1 [i:least(i + $2 - 1, $3
)]) As geom FROM
generate_series(1, $3 , $2 ) As i), $4 + 1, $5 ,
false)"
PL/pgSQL function "upgis_unitecascade_garray" line 48 at
assignment
[ $2 [s]] As geom
FROM generate_series(1, array_upper( $2 ,1)) As s ),
upgis_unitecascade_garray(ARRAY(SELECT $1 [s] As geom
FROM
generate_series(1, $3 ) As s WHERE NOT (s = ANY( $2 ))
), $4 + 1,
$5 , true) ) )"
PL/pgSQL function "upgis_unitecascade_garray" line 33 at
assignment SQL
function "upgis_unitecascade_garray_sort" statement 1
On Oct 4, 2008, at 4:53 PM, Paragon Corporation wrote:
Oops sorry about that.
Just realized I had ugly spaces in the link.
I've changed it. Use
this one
http://postgis.refractions.net/support/wiki/index.php?upgis_cascadeuni
on
Paragon Corporation
Sent: Saturday, October 04, 2008 7:44 PM
Subject: [postgis-users] Cascaded Union
Aggregate function
For those people who have unions to do that are
slow, feel free to try
out this aggregate union function.
I haven't tested it enough for it to make it
into 1.3.4, but have
included a link to the source code in the wiki.
It should work just
fine on PostGIS versions 1.2.2 and above.
http://postgis.refractions.net/support/wiki/index.php?PL%2FPGSQL%20Pse
udo%20 Cascade%20Union%20Aggregate%20Function
Let me know if you run into any problems with
it. It has worked well
for the samples I have used it on.
Thanks,
Regina
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081006/d0d91427/attachment.html>
