[postgis-users] distance bug in "POSTGIS="1.0.6" GEOS="2.2.1" ?
Willy-Bas Loos
willybas at gmail.com
Thu Oct 9 02:51:37 PDT 2008
I nearly fell off my chair yesterday when i saw that distance(), computed on
a self-join, gave a different result for id 1 vs id 2, than for id 2 vs 1.
The geometries are polygons, stored as multipolygons
this is the sql:
select a.gid as aid, b.gid as bid, distance(a.the_geom, b.the_geom)
from table1 a, table1 b
where a.gid != b.gid;
This is the result on "POSTGIS="1.0.6" GEOS="2.2.1" PROJ="Rel. 4.4.9, 29 Oct
2004" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0""
aid | bid | distance
1 | 2 | 7805.02139594382
2 | 1 | 9642.16555369735
But i couldn't reproduce it on my 'POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1"
PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS'
There, the result is:
2 | 1 | 7805.02139594382
Is this a known bug of that version?
"Patriotism is the conviction that your country is superior to all others
because you were born in it." - George Bernard Shaw
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081009/939b8701/attachment.html>
