[postgis-users] Installing PostGre SQL
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Oct 13 04:01:29 PDT 2008
Prestige Makanga wrote:
> Greetings
> I have managed instal PostGreSQL but I am failing to finish off the
> PostGIS install because of a number of errors. Please take a look at the
> error message in the .png attached to this email. What could the problem
> be and how can this be rectified.
> by igoring the errors, the installation still does not complete i get
> the following error before ending the installation process
> "C:/Program Files/PostgreSQL/8.3/share/contrib/lwpostgis.sql: No such
> file or directory"
> There seems to be a missing file. How can i go round this to finish off
> the install.
> Regards
Hi Prestige,
The issue is that the installer doesn't have permissions to write the
files to the PostgreSQL installation directory - you are running this as
an administrator, aren't you?
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
