[postgis-users] Weird behavior - Contains function
cyw at dls.net
cyw at dls.net
Thu Oct 9 08:59:14 PDT 2008
Hi All,
I have a two geo tables:
county - contains polygons of counties for a state
road - all road segments for a state
I tried to delete all the road segments that are not in a specific county
(porter) with this sql:
delete from road where NOT Contains((select the_geom from county where
polygon_nm='porter'), the_geom)
When I examined the results, I found that some segments in the middle of the
county polygon also got deleted. I noticed these wrongly deleted segments
when I saw gaps in some roads in a map display. These segments are not long
ones that would span across the county.
Thanks,
CYW
