[postgis-users] Intersects/Crosses, Contains/Whthin
cyw at dls.net
cyw at dls.net
Thu Oct 9 11:25:48 PDT 2008
Are these functions the same? If so why keeping the duplication?
I have two tables, one is polygons representing counties, and one multiline
segments representing road segments. The roads are broken into these
segments whenever there they intersect with other roads, so these segments
are not very longs.
I want to delete all road segments that are not in a county or cross the
border of that county, is the sql below right for that purpose?
delete from road where
NOT Contains((select the_geom from county where
polygon_nm='A_SPECIFIC_COUNTYNAME'), the_geom)
AND
NOT Intersects((select the_geom from county where
polygon_nm='A_SPECIFIC_COUNTYNAME'), the_geom) ;
The above query for some reason also deletes some road segments in the
middle of the county polygon.
Thanks,
CYW
