[postgis-users] TRANSFORM failures with some multiploygons - datasample attached
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 9 21:34:14 PDT 2008
Right, so what you are seeing is an artefact of PgAdmin, not a problem
with PostGIS. PgAdmin doesn't like displaying fields of more than a
certain length.
P.
On Thu, Oct 9, 2008 at 9:04 PM, <cyw at dls.net> wrote:
> See attached. I viewed it fom PgAdmin UI. Did the queries you suggested,
> the_geom was not NULL.
> The sql below returns nothing:
> select gid, the_geom from city where the_geom is null;
> The sql below returns npoints = 218:
> select gid, npoints(the_geom) from city where polygon_id=35665106;
> Thanks,
> CYW
> ----- Original Message ----- From: "Paul Ramsey" <pramsey at cleverelephant.ca>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, October 09, 2008 10:12 PM
> Subject: Re: [postgis-users] TRANSFORM failures with some multiploygons -
> datasample attached
>>>> It ran without any error. But some of the resulted values in the_geom
>>>> column became null or empty.
>> How did you check this?
>> select gid from thetable where the_geom is null?
>> select gid from thetabel where npoints(the_geom) =
>> P
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
