[postgis-users] TRANSFORM failures with some multiploygons - datasample attached
Luigi Castro Cardeles luigi.cardeles at gmail.com
Thu Oct 9 21:40:32 PDT 2008
maybe this is some type of bug from pgadmin3. sometimes it did not show the
contents of the_geom column.
if your analyse of empty geometry is only at pgadmin so you are wrong and
your the_geom columns are not empty (select gid, the_geom from city where
the_geom is null returns nothing;).
try using psql to see some geometry.
best regards,
2008/10/10 <cyw at dls.net>
> See attached. I viewed it fom PgAdmin UI.  Did the queries you suggested,
> the_geom was not NULL.
> The sql below returns nothing:
>             select gid, the_geom from city where the_geom is null;
> The sql below returns npoints = 218:
>   select gid, npoints(the_geom) from city where polygon_id=35665106;
> Thanks,
> CYW
> ----- Original Message ----- From: "Paul Ramsey" <
> pramsey at cleverelephant.ca>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, October 09, 2008 10:12 PM
> Subject: Re: [postgis-users] TRANSFORM failures with some multiploygons -
> datasample attached
>  It ran without any error. But some of the resulted values in the_geom
>>>> column became null or empty.
>> How did you check this?
>> select gid from thetable where the_geom is null?
>> select gid from thetabel where npoints(the_geom) =
>> P
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081010/6fe64c92/attachment.html>
