[postgis-users] PostGIS Transform and Quantum GIS
cyw at dls.net
cyw at dls.net
Fri Oct 10 07:16:19 PDT 2008
Just wonder if anyone had similar experience.
I have a table with multipolygons for cities (in latitude/longitude,
srid=4326), I could display it with QuantumGIS.
Then I did a transform to a plane coordinate system, and verified the result
(astext(the_geom)) and saw no problem.
Then I tried to view it again with QuantumGIS. Though no error message,
nothing could be display. After zoom-to-layer, the cursor coordinate values
were consitent with the extent of the data in the projected coordinate
system.
Below are the SQL command I did:
ALTER TABLE city DROP CONSTRAINT enforce_srid_the_geom;
update city set the_geom=transform(the_geom,26971) where
polygon_id=35665106;
alter table city add CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom)
= 26971);
Thanks,
CYW
