[postgis-users] transform - update lake setthe_geom=transform(the_geom, 26971)
cyw at dls.net cyw at dls.net
Fri Oct 10 08:21:49 PDT 2008
Thanks to all.
The problem in my case was that I relied on PgAdmin doing my SQL queries and
it does not display certain fields if they are too long.
CYW
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, October 10, 2008 10:00 AM
Subject: Re: [postgis-users] transform - update lake
>> I have a table city which contains Multipolygons (SRID=4326) in latitude
>> and
>> longitude. To project it to  a plane coordinate (SRID=26971), I did:
>>   update lake set the_geom=transform(the_geom, 26971);
>> It ran without any error. But some of the resulted values in the_geom
>> column
>> became null or empty.
>> Any hitnts why it did this?
>> Before the transformation, I viewed the table with QuantumGIS, it looked
>> OK.
>> Afterwards, QuantumGIS showed nothing.
> Hi,
> Verify that your input table has longitude-latitude values as X-Y
> coordinate, not the contrary.
> Also, if some input data fall outside of the range of acceptable
> values for the 26971 projection, these data won't be transformed =>
> null values.
> Nicolas
> postgis-users mailing list
