[postgis-users] GeometryCollection after ST_Centroid(ST_Dump)
Birgit Laggner
birgit.laggner at vti.bund.de
Wed Oct 15 07:23:38 PDT 2008
ahhh! thank you very much. I thought, I've always made a validity check
but this clearly proves the contrary :-)
ok, this is something, I can change - very good.
Thank you, Regina!
Regards,
Birgit.
Obe, Regina schrieb:
> Ah I see the problem now.
> SELECT ST_AsText(ST_Centroid(ST_GeomFromTExt('POLYGON((3713601.737
> 5966193.371,3713601.737 5966193.371,3713601.737
> 5966193.371))')))
> Returns - "GEOMETRYCOLLECTION EMPTY"
> The problem is that polygon is invalid.
> If I do this
> SELECT ST_IsValid(ST_GeomFromTExt('POLYGON((3713601.737
> 5966193.371,3713601.737 5966193.371))'))
> I get
> f and a notice that says
> NOTICE: Too few points in geometry component at or near point
> 3.7136e+06 5.96619e+06
> So I guess the moral of the story - change your query to include a
> WHERE ST_IsValid(abdump.newgeom)
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Birgit Laggner
> Sent: Wednesday, October 15, 2008 9:56 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] GeometryCollection after
> Hi Regina,
> this is the result, I get from the query you sent me:
> gid geometrytype_centroid astxtrep
> integer text text
> 119810 "GEOMETRYCOLLECTION" "POLYGON((3713601.737
> 5966193.371,3713601.737 5966193.371))"
> Thanks and regards,
> Birgit.
>> Birgit,
>> Ah that is weird - I've never seen it return a geometry collection
>> before. So what is the ST_AsText/ST_AsBinary of the first.
>> e.g.
>> SELECT
>> abdump.gid,
>> geometrytype(ST_Centroid(abdump.newgeom)) As geometrytype_centroid,
>> ST_AsText(abdump.newgeom) as astxtrep
>> FROM
>> (SELECT (ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom As
>> newgeom, a.gid, a.the_geom as a_the_geom, b.the_geom as b_the_geom
>> FROM bfn.test_mv_dlm07_dump a, bfn.test_mv_dlm07_dump b
>> WHERE ST_Overlaps(a.the_geom,b.the_geom)=true AND
>> Intersects(a.the_geom,b.the_geom)=true
>> ) As abdump
>> WHERE abdump.gid = 119810
>> GROUP BY (ST_Centroid(abdump.newgeom)),
>> ST_Area(ST_Centroid(abdump.newgeom)),
>> ST_Perimeter(ST_Centroid(abdump.newgeom)), abdump.gid, abdump.newgeom;
>> By the way the result you sent doesn't match the query - its missing a
>> field and the labels don't match the query.
> Yes, that's true - I first made the query with the geom
> (abdump.newgeom), but then deleted this from the query because the geom
> would have needed such a wide column in the result table. And I forgot
> to update this in my e-mail...
>> Hope that helps,
>> Regina
>> Birgit Laggner
>> Sent: Wednesday, October 15, 2008 8:45 AM
>> Hi Regina,
>> yes, that's true. The queries you took for testing work for me, too.
>> But if I try to run:
>> SELECT
>> ST_X(st_centroid((ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom)) AS x_centroid,
>> ST_Y(st_centroid((ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom)) AS y_centroid,
>> ST_Area((ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom) AS
>> area,
>> ST_Perimeter((ST_Dump(ST_Intersection(a.the_geom,
> b.the_geom))).geom)
>> AS perimeter
>> WHERE ST_OVERLAPS(a.the_geom,b.the_geom)=true AND
>> INTERSECTS(a.the_geom,b.the_geom)=true
>> GROUP BY ST_X(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom)),
>> ST_Y(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom)), ST_Area((ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom), ST_Perimeter((ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom), a.the_geom, b.the_geom
>> ORDER BY x_centroid asc, y_centroid asc, area asc, perimeter asc;
>> I still get: error: Argument to X() must be a point.
>> The same happens when I formulate the query like you suggested in the
>> beginning:
>> SELECT
>> abdump.gid,
>> ST_X(ST_Centroid(abdump.newgeom)) As x_centroid,
>> ST_Y(ST_Centroid(abdump.newgeom)) As y_centroid,
>> ST_Area(ST_Centroid(abdump.newgeom)) As area,
>> ST_Perimeter(ST_Centroid(abdump.newgeom)) as perimeter,
>> abdump.newgeom
>> FROM
>> FROM bfn.test_mv_dlm07 a, bfn.test_mv_dlm07 b
>> ) As abdump
>> GROUP BY ST_X(ST_Centroid(abdump.newgeom)),
>> ST_Y(ST_Centroid(abdump.newgeom)),
>> --a_the_geom, b_the_geom
>> ORDER BY x_centroid asc, y_centroid asc, area asc, perimeter asc,
>> abdump.gid asc;
>> Meanwhile, I am a bit confused, because I see no logic in what
>> happens...
>> Just to explain what I thougt, the problem might be:
>> When I run the following query:
>> SELECT
>> abdump.gid,
>> abdump.newgeom
>> FROM
>> ) As abdump
>> I get this in return:
>> gid geometrytype
>> integer text
>> 120217 "GEOMETRYCOLLECTION"
>> 135837 "GEOMETRYCOLLECTION"
>> 101408 "GEOMETRYCOLLECTION"
>> 254497 "GEOMETRYCOLLECTION"
>> 125720 "GEOMETRYCOLLECTION"
>> 125731 "GEOMETRYCOLLECTION"
>> 405587 "POINT"
>> 412179 "POINT"
>> 412179 "POINT"
>> 405587 "POINT"
>> 254497 "POINT"
>> 242621 "POINT"
>> 242621 "POINT"
>> 254497 "POINT"
>> 242621 "POINT"
>> 254497 "POINT"
>> 242621 "POINT"
>> 254497 "POINT"
>> 242621 "POINT"
>> 254497 "POINT"
>> 135850 "GEOMETRYCOLLECTION"
>> 244155 "POINT"
>> 254671 "POINT"
>> 244155 "POINT"
>> 254671 "POINT"
>> 244155 "POINT"
>> 254671 "POINT"
>> 254671 "POINT"
>> 244155 "POINT"
>> 125742 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 125742 "GEOMETRYCOLLECTION"
>> 135850 "POINT"
>> 125742 "POINT"
>> 134472 "GEOMETRYCOLLECTION"
>> 133678 "GEOMETRYCOLLECTION"
>> 126954 "GEOMETRYCOLLECTION"
>> 135850 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 135829 "GEOMETRYCOLLECTION"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 412179 "GEOMETRYCOLLECTION"
>> 125731 "POINT"
>> 135829 "POINT"
>> 135850 "POINT"
>> 125742 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 135829 "POINT"
>> 125731 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 125720 "POINT"
>> 135850 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 135850 "POINT"
>> 125742 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125731 "POINT"
>> 135850 "POINT"
>> 244155 "GEOMETRYCOLLECTION"
>> 242621 "GEOMETRYCOLLECTION"
>> 125731 "POINT"
>> 135829 "POINT"
>> 125742 "POINT"
>> 135850 "POINT"
>> 135837 "POINT"
>> 125720 "POINT"
>> 125720 "POINT"
>> 135837 "POINT"
>> 245042 "GEOMETRYCOLLECTION"
>> 253750 "GEOMETRYCOLLECTION"
>> 125720 "POINT"
>> 135837 "POINT"
>> 125720 "POINT"
>> 135850 "POINT"
>> 375311 "GEOMETRYCOLLECTION"
>> 405587 "GEOMETRYCOLLECTION"
>> 376289 "GEOMETRYCOLLECTION"
>> 254671 "GEOMETRYCOLLECTION"
>> 135837 "POINT"
>> 125720 "POINT"
>> 125720 "POINT"
>> 404117 "GEOMETRYCOLLECTION"
>> 135837 "POINT"
>> 386583 "GEOMETRYCOLLECTION"
>> 386466 "GEOMETRYCOLLECTION"
>> 125720 "POINT"
>> 135837 "POINT"
>> 125720 "POINT"
>> 135837 "POINT"
>> 125720 "POINT"
>> 135837 "POINT"
>> 125720 "POINT"
>> 135837 "POINT"
>> 426566 "GEOMETRYCOLLECTION"
>> This is why I think, the ST_Centroid produces a geometrycollection.
>> Thanks again!
>> Regards,
>> Birgit.
>>> Birgit,
>>> I just loaded up this data set you posted and tried doing
>>> SELECT ST_X(ST_Centroid(the_geom))
>>> FROM test_mv_dlm07_dump;
>>> Works perfectly fine for me. Even if you pass a geometry collection
>> to ST_Centroid, it would always return a point.
>>> To demonstrate
>>> SELECT ST_GeometryType(ST_Centroid(ST_Collect(the_geom))),
>> ST_AsText(ST_Centroid(ST_Collect(the_geom))) as full_cent
>>> Gives me this:
>>> "ST_Point";"POINT(3728516.33771743 5964986.31004069)"
>>> Are you saying the sample you posted when you do the above doesn't
>> work for you? If so, then there appears to be something wrong with
> your
>> install.
>>> What does
>>> SELECT postgis_full_version();
>>> return for you?
>> "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
> 2007"
>> USE_STATS"
>>> Thanks,
>>> Regina
>> Birgit Laggner
>>> Sent: Wednesday, October 15, 2008 5:03 AM
>>> Hi Regina,
>>> thanks for your response! I tried the query you suggested and still
>> get
>>> the same result (error: Argument to X() must be a point), which is
>>> totally reasonable, regarding that the result of the ST_Centroid is
>>> still a GeometryCollection. My guess was, that this is caused by the
>>> fact that ST_Dump returns not only POLYGONs but also LINESTRINGs and
>>> POINTs. I thought, it could be that ST_Centroid has difficulties
>>> returning a centroid for points and linestrings. So, what I did so
>> far,
>>> was to split the query into one part, with which I just find all
>>> overlapping geometries without grouping or anything else, and one
>> part,
>>> which does the grouping including calculating of the centroid and
>>> everything else. And, between these two parts, I just delete all
>>> geometries that are LINESTRINGs or POINTs (I don't need them, I only
>>> need the polygons). At least, these queries run - I don't know yet if
>>> the result is correct...
>>> But, as I saw now, when I selected the data example you asked for
> (see
>>> attachement), that the GeometrieCollections don't occur at the
>>> linestring or point geometries as I expected. There seems to be some
>>> other problem, I don't understand...
>>> Here my new (working) query:
>>> CREATE TABLE bfn.mv_dlm07_olvg
>>> gid serial NOT NULL,
>>> gid_mv_dlm07 integer
>>> SELECT
> AddGeometryColumn('bfn','mv_dlm07_olvg','the_geom','31467','MULTIPOLYGON
>> ',2);
>>> ALTER TABLE bfn.mv_dlm07_olvg DROP CONSTRAINT
>> enforce_geotype_the_geom;
>>> INSERT INTO bfn.mv_dlm07_olvg (
>>> gid_mv_dlm07,
>>> the_geom)
>>> SELECT
>>> a.gid,
>>> (ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom AS the_geom
>>> FROM bfn.mv_dlm07_orig a, bfn.mv_dlm07_orig b
>>> INTERSECTS(a.the_geom,b.the_geom)=true;
>>> DELETE FROM bfn.mv_dlm07_olvg
>>> WHERE GeometryType(the_geom)='LINESTRING';
>>> WHERE GeometryType(the_geom)='POINT';
>>> gid_mv_dlm07 integer,
>>> x_centroid numeric,
>>> y_centroid numeric,
>>> area numeric,
>>> perimeter numeric
>>> SELECT
> AddGeometryColumn('bfn','mv_dlm07_ol','the_geom','31467','MULTIPOLYGON',
>> 2);
>>> ALTER TABLE bfn.mv_dlm07_ol DROP CONSTRAINT enforce_geotype_the_geom;
>>> INSERT INTO bfn.mv_dlm07_ol (
>>> gid_mv_dlm07,
>>> x_centroid,
>>> y_centroid,
>>> area,
>>> perimeter,
>>> the_geom)
>>> SELECT
>>> a.gid_mv_dlm07,
>>> st_x(st_centroid(a.the_geom)) as x_centroid,
>>> st_y(st_centroid(a.the_geom)) as y_centroid,
>>> st_area(a.the_geom) as area,
>>> st_perimeter(a.the_geom) as perimeter,
>>> a.the_geom as the_geom
>>> FROM bfn.mv_dlm07_olvg a
>>> GROUP BY st_x(st_centroid(a.the_geom)),
> st_y(st_centroid(a.the_geom)),
>>> st_area(a.the_geom), st_perimeter(a.the_geom), a.the_geom
>>> a.gid_mv_dlm07 asc;
>>> Regards,
>>> Birgit.
>>>> Birgit,
>>>> So you are saying ST_Centroid sometimes returns geometry
> collections.
>>>> Hmm I don't see how that is possible unless there is bug somewhere.
>>>> Can you provide an example of that.
>>> Is attached - these are the ones which return GeometryCollection
> after
>>> ST_Centroid. I had to remove the attributes because of privacy
>> reasons.
>>>> Regarding the below query - it
>>>> would be a bit easier to follow if you did a subselect first.
>>>> Something like
>>>> SELECT
>>>> abdump.gid,
>>>> abdump.objart_07,
>>>> abdump.cat_07,
>>>> FROM (SELECT (ST_Dump(ST_Intersection(a.the_geom,
>>>> b.the_geom))).geom As newgeom, a.gid, a.objart_07, a.cat_07,
>> a.the_geom
>>>> FROM
>>>> ) As abdump
>> abdump.objart_07,
>>>> abdump.cat_07, a_the_geom, b_the_geom
>> a.gid
>>>> asc;
>>>> Hope that helps,
>>>> Regina
>>>> Birgit Laggner
>>>> Sent: Tuesday, October 14, 2008 6:56 AM
>>>> Subject: [postgis-users] GeometryCollection after
>>>> Dear list,
>>>> I have a SELECT statement in which I try to group by the polygons
>>>> resulting from a self intersection. After I realized that I can't
>> group
>>>> by the_geom because this would group polygons which are only similar
>> but
>>>> not equal, I decided to group by the area, the perimeter and the x-
>> and
>>>> y-coordinates of the centroid of every polygon. The SELECT statement
>> I
>>>> wrote, worked so far for some test datasets and showed seemingly
>>>> reasonable results. But for at least one of my datasets, the
>> statement
>>>> does not work, because the ST_Centroid produces some
>> GeometryCollections
>>>> instead of POINTS. What could cause that problem and how can I solve
>>>> it???
>>>> This is my statement:
>>>> SELECT
>>>> a.gid,
>>>> a.objart_07,
>>>> a.cat_07,
>>>> b.the_geom))).geom)) as x_centroid,
>>>> b.the_geom))).geom)) as y_centroid,
> as
>>>> area,
>> b.the_geom))).geom)
>>>> as perimeter,
>>>> (ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom as
> the_geom
>>>> b.the_geom))).geom), a.gid, a.objart_07, a.cat_07, a.the_geom,
>>>> b.the_geom
>> a.gid
>>>> asc;
>>>> The ST_Dump results in POLYGONs, LINESTRINGs and POINTs.
>>>> Thank you for any help!
>>>> Regards,
>>>> Birgit.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
