[postgis-users] Contains failing
Fred Lehodey lehodey at gmail.com
Wed Oct 15 09:23:46 PDT 2008
Hi,I have the same results as David: (false)
postgis_full_version():
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS"
Fred.
On Wed, Oct 15, 2008 at 5:09 PM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> I don't get your results - I get TRUE in both cases.
> What version of postgis/geos are you running?
> -- Kevin
> David Vaz wrote:
>> Hi,
>> Does anyone have a clue why this fails:
>> select contains(geomfromtext('POLYGON((0 0,0 8,8 8,8 0,0 0),(3 3,5 3,5
>> 5,3 5,3 3))'), geomfromtext('POLYGON((0 0,5 0,5 1,0 1,0 0))'))
>>  contains
>>  f
>> (1 row)
>> Without the Hole in the polygon
>> select contains(geomfromtext('POLYGON((0 0,0 8,8 8,8 0,0 0))'),
>>  contains
>>  t
>> (1 row)
>> And the Hole does not intersects the other polygon
>> select intersects(geomfromtext('POLYGON((3 3,5 3,5 5,3 5,3 3))'),
>>  intersects
>>  f
>> (1 row)
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081015/5bffccbf/attachment.html>
