[postgis-users] Contains failing
Paul Ramsey
pramsey at cleverelephant.ca
Wed Oct 15 09:31:34 PDT 2008
There's a contains bug in GEOS 3.0.0
We need to cut 3.0.1
P
On Wed, Oct 15, 2008 at 9:23 AM, Fred Lehodey <lehodey at gmail.com> wrote:
> Hi,
> I have the same results as David: (false)
> postgis_full_version():
> "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
> USE_STATS"
> Fred.
> On Wed, Oct 15, 2008 at 5:09 PM, Kevin Neufeld <kneufeld at refractions.net>
> wrote:
>> I don't get your results - I get TRUE in both cases.
>> What version of postgis/geos are you running?
>> -- Kevin
>> David Vaz wrote:
>>> Hi,
>>> Does anyone have a clue why this fails:
>>> select contains(geomfromtext('POLYGON((0 0,0 8,8 8,8 0,0 0),(3 3,5 3,5
>>> 5,3 5,3 3))'), geomfromtext('POLYGON((0 0,5 0,5 1,0 1,0 0))'))
>>> contains
>>> f
>>> (1 row)
>>> Without the Hole in the polygon
>>> select contains(geomfromtext('POLYGON((0 0,0 8,8 8,8 0,0 0))'),
>>> contains
>>> t
>>> (1 row)
>>> And the Hole does not intersects the other polygon
>>> select intersects(geomfromtext('POLYGON((3 3,5 3,5 5,3 5,3 3))'),
>>> intersects
>>> f
>>> (1 row)
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
