[postgis-users] Standard projection for continental US?
David Jantzen
david at culturemob.com
Fri Oct 17 17:04:43 PDT 2008
Thanks Regina, that looks like a good option. Distance from Seattle to
Miami is 2717 miles under SRID 2163 versus 2730 miles under the custom
projection. Definitely close enough for what I'm doing.
On Fri, 2008-10-17 at 15:47 -0400, Obe, Regina wrote:
> I usually us US National Atlas Equal Area - Meters (SRID 2163)
> Though maybe I should try the below and see how my numbers match up.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> David Jantzen
> Sent: Friday, October 17, 2008 3:35 PM
> To: postgis
> Subject: [postgis-users] Standard projection for continental US?
> Hey All,
> I'm wondering if there's an official or standard projection that covers
> the continental US? When I first joined the list, Paul kindly provided
> this:
> INSERT INTO SPATIAL_REF_SYS VALUES (1000000,'ME',1000000,'','+proj=aea
> +lat_0=23 +lon_0=-96 +lat_1=29.5 +lat_2=45.5 +datum=NAD83
> +ellps=GRS80');
> It seems to work accurately enough, I'm just curious if there's a
> standard definition like those in spatial_ref_sys.sql.
> Thanks,
> David
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
