[postgis-users] Table w/existing geometry column (without AddGeometryColumn), SRID?
Kristian Thy
thy at 42.dk
Thu Oct 23 11:33:41 PDT 2008
On Thu, Oct 23, Kevin Neufeld wrote:
> Did you try probe_geometry_columns()?
> It scans the system tables looking for the constraints usually assigned
> to a geometry column and inserts the discovery into the
> public.geometry_columns table.
Interesting. I searched the docs just now, and only found one reference
to the function - it's mentioned as having received a bugfix, but
nowhere can you see what it does :)
Thanks for the pointer.
> Alternatively, you can use the attached plpgsql that I use all the time.
Saved to the scratchpad, thanks.
\\kristian
... et nemo ex vobis interrogat me: »Quo vadis?«
