[postgis-users] Table w/existing geometry column (without AddGeometryColumn), SRID?
Kevin Neufeld
kneufeld at refractions.net
Thu Oct 23 12:03:22 PDT 2008
Yup, it looks like the docs are missing for that function in 1.3.3 as
well as the current 1.3.4SVN development branch.
However, a simple explanation did manage to get into the new
documentation we are working on for version 1.4.
http://postgis.refractions.net/documentation/manual-svn/Probe_Geometry_Columns.html
I just added the same description to the 1.3.4SVN development branch so
it should make it into 1.3.4 when it's finally released (I think
1.3.4rc2 should come out soon).
Cheers,
Kevin
Kristian Thy wrote:
> On Thu, Oct 23, Kevin Neufeld wrote:
>> Did you try probe_geometry_columns()?
>> It scans the system tables looking for the constraints usually assigned
>> to a geometry column and inserts the discovery into the
>> public.geometry_columns table.
> Interesting. I searched the docs just now, and only found one reference
> to the function - it's mentioned as having received a bugfix, but
> nowhere can you see what it does :)
> Thanks for the pointer.
>> Alternatively, you can use the attached plpgsql that I use all the time.
> Saved to the scratchpad, thanks.
> \\kristian
