[postgis-users] Intersection of 2 large maps overlap at a corner
Bob and Deb
bobdebm at gmail.com
Fri Oct 24 15:04:11 PDT 2008
I tried reversing the test and I'm still having the same problem. Here is
some information I got from pgadmin3 concerning my tables:
CREATE TABLE sf_quat_geopy
gid serial NOT NULL,
sf_quat_ numeric,
sf_quat_id numeric,
ptype character varying(35),
name character varying(200),
liq character varying(8),
liq_source bigint,
area numeric,
perimeter numeric,
e00_centro numeric,
e00_centr1 numeric,
the_geom geometry,
CONSTRAINT sf_quat_geopy_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 32610)
CREATE INDEX sf_quat_geopy_key
ON sf_quat_geopy
USING btree
(ptype);
CREATE INDEX sf_quat_geopy_the_geom_gist
ON sf_quat_geopy
USING gist
(the_geom);
CREATE TABLE sj_100k_geopy
sj_geol_ numeric,
sj_geol_id numeric,
area numeric,
perimeter numeric,
e00_centro numeric,
e00_centr1 numeric,
the_geom geometry,
CONSTRAINT sj_100k_geopy_pkey PRIMARY KEY (gid),
CREATE INDEX sj_100k_geopy_ptype
ON sj_100k_geopy
USING btree
(ptype);
CREATE INDEX sj_100k_geopy_the_geom_gist
ON sj_100k_geopy
USING gist
(the_geom);
Nested Loop (cost=0.00..8226.67 rows=4509 width=15085)
Join Filter: _st_intersects(geob.the_geom, geoq.the_geom)
-> Seq Scan on sj_100k_geopy geob (cost=0.00..993.00 rows=7407
width=6918)
Filter: ((ptype)::text <> ALL ('{Qls,Qls?}'::text[]))
-> Index Scan using sf_quat_geopy_the_geom_gist on sf_quat_geopy geoq
(cost=0.00..0.96 rows=1 width=8167)
Index Cond: (geob.the_geom && geoq.the_geom)
Filter: ((geoq.ptype)::text <> ALL ('{br,br?}'::text[]))
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081024/51b404d4/attachment.html>
