[postgis-users] Intersection of 2 large maps overlap at a corner
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Oct 25 15:12:12 PDT 2008
Regina,
I came across an optimizer issue with IN of the form:
A IN (B, C) that would not use the index but
A=B or A=C that would use the index.
So you might be on track with your suggestion below. I thought it was
strange at the time and that I might have been doing something wrong so
I'm glad you mentioned it also.
-Steve W.
Paragon Corporation wrote:
> Looks like its not using the ptype index and opting to do a sequential
> scan. That could be right since you are using a NOT IN and if the stats
> say most of the table fits the condition it ouwld rightfully not use the
> index.
> Did you run a
> vacuum analyze st_quat_geopy;
> vacuum analyze sj_100k_geopy ;
> I recall seeing some strange behavior with IN clause, but I dismissed it
> as an issue with constraint exclusion not being able to optimize the IN
> since I was using it in context of constraint exclusion and it wasn't
> behaving as I was expecting.
> If vacuum analyzing doesn't help
> try changing your query to use
> NOT (a = b OR a = c)
> instead of
> a NOT IN(b,c)
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Bob and Deb
> *Sent:* Friday, October 24, 2008 6:04 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Intersection of 2 large maps overlap at a
> corner
> I tried reversing the test and I'm still having the same problem. Here
> is some information I got from pgadmin3 concerning my tables:
> CREATE TABLE sf_quat_geopy
> gid serial NOT NULL,
> sf_quat_ numeric,
> sf_quat_id numeric,
> ptype character varying(35),
> name character varying(200),
> liq character varying(8),
> liq_source bigint,
> area numeric,
> perimeter numeric,
> e00_centro numeric,
> e00_centr1 numeric,
> the_geom geometry,
> CONSTRAINT sf_quat_geopy_pkey PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 32610)
> CREATE INDEX sf_quat_geopy_key
> ON sf_quat_geopy
> USING btree
> (ptype);
> CREATE INDEX sf_quat_geopy_the_geom_gist
> ON sf_quat_geopy
> USING gist
> (the_geom);
> CREATE TABLE sj_100k_geopy
> sj_geol_ numeric,
> sj_geol_id numeric,
> area numeric,
> perimeter numeric,
> e00_centro numeric,
> e00_centr1 numeric,
> the_geom geometry,
> CONSTRAINT sj_100k_geopy_pkey PRIMARY KEY (gid),
> CREATE INDEX sj_100k_geopy_ptype
> ON sj_100k_geopy
> USING btree
> (ptype);
> CREATE INDEX sj_100k_geopy_the_geom_gist
> ON sj_100k_geopy
> USING gist
> (the_geom);
> Nested Loop (cost=0.00..8226.67 rows=4509 width=15085)
> Join Filter: _st_intersects(geob.the_geom, geoq.the_geom)
> -> Seq Scan on sj_100k_geopy geob (cost=0.00..993.00 rows=7407
> width=6918)
> Filter: ((ptype)::text <> ALL ('{Qls,Qls?}'::text[]))
> -> Index Scan using sf_quat_geopy_the_geom_gist on sf_quat_geopy
> geoq (cost=0.00..0.96 rows=1 width=8167)
> Index Cond: (geob.the_geom && geoq.the_geom)
> Filter: ((geoq.ptype)::text <> ALL ('{br,br?}'::text[]))
> postgis-users mailing list
