[postgis-users] SRID confusion
pcreso at pcreso.com
Thu Oct 30 18:31:13 PDT 2008
Hi Regina,
Still using 1.1 on this system.
The isssue I have is that any geometry created by a postgis geometry processing function has a SRID there for each individual polygon within the multipOLYGON.
This causes QGIS to crash, & the internal SRID is always reported as 0 by astext().
If I extract the astext() output, cut out the internal SRID, & re-insert to the table without this, everything seems happy, & astext() returns the text with no SRID for the constituent polygons & QGIS is fine
This may have been addressed in later versions of PostGIS, but I don't recall any mentions of this as a bug or problem for anyone else.
This means there are two acceptable formats for a PostGIS multipolygon (both acceptable with isvalid() for example), one with internal SRID values & one without, applications such as QGIS are happy with geometries which do NOT have the internal SRID specified, but PostGIS is only creating multipolygons with the internal SIDs explicitly specified.
Cheers....
Brent
--- On Fri, 10/31/08, Paragon Corporation <lr at pcorp.us> wrote:
> From: Paragon Corporation <lr at pcorp.us>
> Subject: RE: [postgis-users] SRID confusion
> To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
> Date: Friday, October 31, 2008, 11:01 AM
> Brent,
> Which version of PostGIS are you using? I'm guessing
> an older version.
> If I do this
> SELECT AsText('SRID=4326;POLYGON((1 2 3, 4 5 6, 7 8 9,
> 1 2 3))')
> I get this
> "POLYGON((1 2,4 5,7 8,1 2))"
> Which observe has no SRID information.
> If I do this
> SELECT AsEWKT('SRID=4326;POLYGON((1 2 3, 4 5 6, 7 8 9,
> 1 2 3))')
> I get
> "SRID=4326;POLYGON((1 2 3,4 5 6,7 8 9,1 2 3))"
> (which observe maintains the SRID info)
> So maybe an earlier version included an SRID which would
> obviously be 0 or
> -1 since it basically throws that information away so is
> for all intents and
> purposes is forced to unknown now.
> So I guess my only suggestion - stay away from AsText if
> you care about SRID
> And Use ST_AsEWKT or AsEWKT instead and ST_GeomFromEWKT or
> GeomFromEWKT.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of
> Sent: Thursday, October 30, 2008 5:37 PM
> To: PostGIS Users Discussion
> Hi Regina...
> To add to my confusion:
> I'm using AsText, as in the original example below.
> If I try to open this multipolygon with QGIS (v1 pre or
> v0.11) it crashes.
> However:
> If I do the following in a shell script:
> GEOM=`psql -d $DB -Atc "select astext(hole) from
> hole_multi;"` GEOM=`echo
> "$GEOM" | sed 's/SRID=0;//g'` psql -d $DB
> -c "update hole_multi set
> hole=geometryfromtext('$GEOM',4326);"
> ie: remove any internal reference to the SRID & update
> the geomtery value
> from the revised text string, then everything works
> perfectly.
> Is this a bug in how geomunion() write the geometry? Does
> it include the
> constituent SRID's when it shouldn't?
> Thanks
> Brent
> > Date: Friday, October 31, 2008, 10:14 AM Brent,
> > Are you using AsText or ST_AsEWKT.
> > AsText to my knowledges doesn't output SRID so it
> would always be 0.
> > Hope that helps,
> > Regina
> On Behalf Of
> > Sent: Thursday, October 30, 2008 4:53 PM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] SRID confusion
> > Hi guys,
> > I'm not sure what is going on here:
> > I am working with some strata boundaries for a
> fisheries survey,
> > mostly depth based strata. SRID=4326
> > I also have some polygons of areas of untrawlable
> seabed & want to
> > generate these cropped by stratum. SRID=4326
> > Aas a step in this process I create a new table with a
> single
> > multipolygon comprising the geomunion of all the hole
> polygons.
> > SRID=4326
> > insert into hole_multi
> > select 1, geomunion(geom) from holes;
> > If I run a query on this table:
> > select srid(hole), astext(hole) from hole_multi;
> > I get:
> > 4326 | MULTIPOLYGON(SRID=0;((55.78 ....
> > So the SRID of the column is 4326, but each
> constituent polygon of the
> > multipolygon, despite coming from a 4326 dataset,
> seems to be set
> > internally to SRID=0.
> > The result is the same with:
> > select 1,
> setsrid(geomunion(geom),4326) from holes;
> > Any ideas?
> > Thanks,
> > Brent Wood
> > postgis-users mailing list
