[postgis-users] Using ST_<function> (doesn't work)
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 31 12:30:42 PDT 2008
Either you are working on an old database with the new library
underneath, or you accidentally loaded the old lwpostgis.sql file into
a new database. Go back and review your install procedure, you'll find
the problem there.
P.
On Fri, Oct 31, 2008 at 12:08 PM, lisek lichu <lisek.lichu at gmail.com> wrote:
> Ok it works but I know that way but my problem is what to do to work
> on new functions with ST prefix :)
> thanks anyway
> postgis-users mailing list
