[postgis-users] Problem with records being stripped out
Mary Whelan
Mary.Whelan at asu.edu
Tue Oct 7 16:01:35 PDT 2008
We use a stack of GeoServer, PostGIS, and Open Layers. When I try to
load certain shapefiles using the shp2pgsql command, PostGIS seems to
strip out some records but not all. This happens with any US Federal
government shapefiles, I suspect ones derived from Census data (it
happened with Dept. of Agriculture and GNIS shapefiles today). The
error seems to indicate an encoding problem, but when I look at the
original shapefile, there aren't any accent marks or non-English
characters. Can you help me understand what is happening and how to
work around it?
Thanks!
Mary Whelan
Arizona State University
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081007/f09b322c/attachment.html>
