[postgis-users] Problem with records being stripped out
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 7 16:04:55 PDT 2008
Not without some example data....
On Tue, Jul 7, 2009 at 3:51 PM, Mary Whelan<Mary.Whelan at asu.edu> wrote:
> We use a stack of GeoServer, PostGIS, and Open Layers. When I try to load
> certain shapefiles using the shp2pgsql command, PostGIS seems to strip out
> some records but not all. This happens with any US Federal government
> shapefiles, I suspect ones derived from Census data (it happened with Dept.
> of Agriculture and GNIS shapefiles today). The error seems to indicate an
> encoding problem, but when I look at the original shapefile, there aren’t
> any accent marks or non-English characters. Can you help me understand what
> is happening and how to work around it?
> Thanks!
> Mary Whelan
> Arizona State University
> postgis-users mailing list
