[postgis-users] Problem with records being stripped out
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 7 16:05:16 PDT 2008
And a version number of the software you are using.
On Tue, Jul 7, 2009 at 3:55 PM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
> Not without some example data....
> On Tue, Jul 7, 2009 at 3:51 PM, Mary Whelan<Mary.Whelan at asu.edu> wrote:
>> We use a stack of GeoServer, PostGIS, and Open Layers. When I try to load
>> certain shapefiles using the shp2pgsql command, PostGIS seems to strip out
>> some records but not all. This happens with any US Federal government
>> shapefiles, I suspect ones derived from Census data (it happened with Dept.
>> of Agriculture and GNIS shapefiles today). The error seems to indicate an
>> encoding problem, but when I look at the original shapefile, there aren’t
>> any accent marks or non-English characters. Can you help me understand what
>> is happening and how to work around it?
>> Thanks!
>> Mary Whelan
>> Arizona State University
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
