[postgis-users] ST_Contains vs. ST_Within
Kevin Neufeld kneufeld at refractions.net
Thu Sep 4 19:51:48 PDT 2008
They are indeed inverses.  Are both your geometries valid?  Can you
provide a test case?
-- Kevin
cyw at dls.net wrote:
> Thanks. But the two behave differently.
> I tried both with the same data (see below) , Within returned more
> records.
> select * into dupage  from maj where Contains((select the_geom from
> city where area_id=21002891), the_geom)
> select * into dupage  from maj where Within(the_geom, (select the_geom
> from city where area_id=21002891) )
> ----- Original Message ----- From: "Paul Ramsey"
> <pramsey at cleverelephant.ca>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, September 04, 2008 5:59 PM
> Subject: Re: [postgis-users] ST_Contains vs. ST_Within
>> They in inverses.
>> ST_Contains(A,B) <=> ST_Within(B,A)
>> P.
>> On Thu, Sep 4, 2008 at 3:49 PM,  <cyw at dls.net> wrote:
>>> What are the difeerences between these two functions?
>>> Thanks.
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> _______________________________________________ q
