[postgis-users] ST_Contains vs. ST_Within
cyw at dls.net
cyw at dls.net
Thu Sep 4 20:48:22 PDT 2008
You are right. I misread.
Thanks.
cyw
----- Original Message -----
From: "Kevin Neufeld" <kneufeld at refractions.net>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, September 04, 2008 9:51 PM
Subject: Re: [postgis-users] ST_Contains vs. ST_Within
> They are indeed inverses. Are both your geometries valid? Can you
> provide a test case?
> -- Kevin
> cyw at dls.net wrote:
>> Thanks. But the two behave differently.
>> I tried both with the same data (see below) , Within returned more
>> records.
>> select * into dupage from maj where Contains((select the_geom from
>> city where area_id=21002891), the_geom)
>> select * into dupage from maj where Within(the_geom, (select the_geom
>> from city where area_id=21002891) )
>> ----- Original Message ----- From: "Paul Ramsey"
>> <pramsey at cleverelephant.ca>
>> Sent: Thursday, September 04, 2008 5:59 PM
>>> They in inverses.
>>> ST_Contains(A,B) <=> ST_Within(B,A)
>>> P.
>>> On Thu, Sep 4, 2008 at 3:49 PM, <cyw at dls.net> wrote:
>>>> What are the difeerences between these two functions?
>>>> Thanks.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> _______________________________________________ q
