[postgis-users] Generating PNGs from PostGIS
pcreso at pcreso.com
Fri Sep 5 12:32:26 PDT 2008
Another option...
Use ogr2ogr to extract the data you require in GMT multiline format then draw the map with GMT & use ps2raster to generate the png from the GMT postscript output.
Totally script/commandline based & GMT rivals any free or commercial package for quality cartographic output.
I have scripts which pretty much do this. The map extent can be derived from the data to be plotted, standard background layers are plotted, the selected data is overlaid, appropriate text is rendered & a png is created... almost too easy :-)
Cheers,
Brent Wood
--- On Sat, 9/6/08, Dylan Lorimer <edylan at google.com> wrote:
> From: Dylan Lorimer <edylan at google.com>
> Subject: [postgis-users] Generating PNGs from PostGIS
> To: postgis-users at postgis.refractions.net
> Date: Saturday, September 6, 2008, 7:11 AM
> Thanks everyone for the awesome suggestions! Given that I
> need this to be
> command line driven, Mapnik looks to be the best option.
> Though the fact
> that QGIS builds the .map files is tempting as well. In any
> event, thanks
> again for the suggestions. I'll report back on how
> successful I am with
> Mapnik.
> On other thought: what about throwing a WMS on top of
> PostGIS and then
> programmatically requesting the data I need via WMS URL
> request? You can
> pass a SQL query in part of the request using the OGC
> FILTER syntax, right?
> -dylan
> postgis-users mailing list
