[postgis-users] SVG Render Issue
Toby Rainthorpe
toby.rainthorpe at frsltd.co.uk
Sat Sep 6 03:22:04 PDT 2008
I am outputting EPSG 4326 (WGS84) polygon data as svg from postgis. I
am however struggling to get anything to render as SVG. Does anyone
know the correct viewBox and path transform setup to allow this type
of data to render as svg. Or should I be using a different method?
Here is an example of what I am currently doing. The path should
render a low res polygon of Oxford, UK.
Thanks for your help,
Toby
<?xml version="1.0"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd
<svg width="1000px" height="1000px" viewBox="0 0 1000 1000"
version="1.1" xmlns="http://www.w3.org/2000/svg">
<path transform="rotate(-90) scale(100, 100)" d="M
0.921728857893816 -51.667439178992964 -0.943648406641863
-51.632171437283979 -1.034036852747396 -51.615081510110407
-1.039191311589453 -51.598091782046289 -1.033829707386365
-51.556789304415609 -1.1425733621232 -51.557652243792148
-1.145679223489618 -51.547423329173235 -1.189737584965937
-51.532259424970057 -1.229532663338833 -51.530540163435404
-1.250685053075961 -51.535731015755111 -1.312050535540559
-51.548417712963399 -1.425623923601573 -51.509218583082671
-1.428279846417039 -51.508871866780524 -1.513905752021219
-51.547390754456636 -1.559539348757429 -51.544194212449625
-1.552142863881142 -51.552808047302449 -1.541332522749044
-51.592135260652277 -1.485423223611759 -51.612046530991961
-1.451764485328202 -51.660426172863772 -1.434161967168025
-51.707327545117195 -1.47848156540616 -51.702245140035409
-1.609807649184428 -51.689850777223604 -1.620999799213429
-51.740828342840693 -1.628372901372629 -51.754888694562183
-1.722123487421185 -51.786808960161039 -1.708360615052025
-51.839001461487797 -1.704942063318551 -51.840116976257576
-1.690786233278003 -51.880706380276834 -1.603332789259012
-51.953422473934495 -1.587297429691924 -51.973814827929104
-1.523602838008319 -51.984481534794249 -1.543869897542569
-52.09381155015555 -1.512481859689253 -52.068455261898272
-1.444721028482055 -52.135737033033088 -1.427704375949055
-52.138631878072097 -1.331856824432614 -52.168816391950621
-1.262767634105308 -52.14457688819958 -1.207370939790454
-52.127537934403819 -1.16423442917146 -52.121737089323943
-1.159184763425933 -52.1075121412795 -1.179247124874321
-52.086972310756543 -1.242617144599129 -52.060726831549047
-1.248283132968878 -52.058641011110218 -1.224176087740303
-51.986702353558726 -1.148267250655421 -51.972959616664077
-1.094743177288104 -51.971670104237695 -1.090899221646197
-51.9673693174175 -1.015796442422725 -51.922784982564536
-1.008801622188257 -51.920118492786557 -1.010300996939166
-51.905500861451756 -1.037320729582182 -51.875178460936723
-1.045299326181702 -51.863391677882802 -1.095584860875437
-51.833557109123397 -1.106668344949025 -51.824307819728489
-1.059837346061549 -51.746986223607081 -0.998140121763855
-51.759686293695736 -0.96995159142063 -51.764519051940162
-0.932876409075794 -51.751189639314866 -0.90604174112355
-51.733290639496737 -0.881141004715887 -51.688327043177416 Z"
fill="red" stroke="blue" stroke-width="3" />
</svg>
