[postgis-users] postgis install problems
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Sep 8 06:57:35 PDT 2008
Dowling, James Parker wrote:
> Mark,
> I've found the SVN Trunk and will try that. Where do you find PROJ 4.4.9 ?
> Thanks,
> Jim
Hi Jim,
Sorry if I wasn't so clear - what I meant is that SVN trunk is able to
detect the version of PROJ being used, and will error out with a
suitable message if the version you are using is too old. Compiling a
newer version of PROJ (I'd grab the latest stable) and then re-building
PostGIS 1.3.3 should be enough to resolve this.
PROJ can be found at: http://trac.osgeo.org/proj/.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
