[postgis-users] Points inside polygon...
davyd davydky at gmail.com
Tue Sep 9 06:53:12 PDT 2008
Ok Tim...
My points are stored on my database(geometry), but my polygon points are
many records, I need to evaluate if one point is inside of the polygon.
Like this:
select within('01010000202D610000E81559FA0BD62541DA82728C04776241',the_geom
) from buffer8_ida
Result "f" or "t"...
2008/9/8 Tim Bowden <tim.bowden at westnet.com.au>
> On Mon, 2008-09-08 at 16:41 -0500, davyd wrote:
> > Hi List,
> > I need to evaluate if a point is inside of a polygon,
> use ST_Within(pt_geom, polygon_geom)
> >  but my data are very records...
> Not at all sure what you mean by this.  Are you saying your points or
> polygons or both are not stored as postgis geometries?  If not, how are
> they stored?
> Regards,
> Tim Bowden
> > How can I evaluate if a point is inside of all my records..
> > I need to construct a box with all may records??
> > Thanks...!!
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Experience is that marvelous thing that enables you recognize a mistake
> when you make it again.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080909/b8204000/attachment.html>
