[postgis-users] list of the closest borders
Doug Fischer dgf at dfischer.com
Thu Sep 11 08:18:43 PDT 2008
Kevin,
I have played with these functions and created a query however it
does not seem to be producing the correct results.
What I have done is the following (just so you understand the data
that I am working with).
I have downloaded the World shapefile from http://www.cipotato.org/
diva/data/MoreData.htm
I used shp2pgsql to create the inserts for PostGIS into a table
called world_countries with the following definition:
gid - integer
name - character varying(40)
gmi_cntry - character varying(3)
region - character varying(25)
the_geom - geometry
I selected a point close to the canadian border in Montana (lat:
48.400032 long: -107.753906) and ran the following queries
1)
select name, gmi_cntry,
	distance(the_geom,
		GeomFromText('Point(-107.753906 48.400032)', srid(the_geom))) *
69.046767 as distance
	from worl_countries order by distance limit 5;
2)
	distance_sphere(
		line_interpolate_point(
			ExteriorRing(GeometryN(the_geom, 1)),
			line_locate_point(
	) / 1609.344 as distance
	from world_countries order by distance limit 5;
Results of query 1:
United States 	|	USA	|	0
Canada			|	CAN	|	41.42...
Mexico			|	MEX	|	1147.37...
Guatemala		|	GTM	|	2408.14...
Cuba			|	CUB	|	2413.21...
Results of query 2:
United States 	|	USA	|	1277.33...
Mexico			|	MEX	|	1336.31...
Canada			|	CAN	|	1509.44...
Cuba			|	CUB	|	2283.77...
Guatemala		|	GTM	|	2313.55...
As you can see from the results of the 2 queries, they are not even
close.  I understand that the first query is not going to be all that
accuate, but I tthought that the two would at least be in the same
ballpark.  The results from query 1 are more like what I need, I was
just trying to get a little more accurate.  Query 2 seems to be
better when the Point that I am using in the query is not inside of a
country already.
Any ideas?  suggestions?  Anything would be appreciated.
thank you very much,
Doug
On Sep 10, 2008, at 11:34 AM, Kevin Neufeld wrote:
> Yes.  Experiment with
> - ST_Line_Locate_Point(linestring, Point) - which returns a
> percentage along the linestring the point occurs.
> - ST_Line_Interpolate_Point(linestring, location) - which accepts a
> "percentage along" and returns the interpolated point along the
> linestring.
> Since these functions accept a linestring, you could extract the
> exterior ring of your country polygon.
> Something like:
> SELECT
>     ST_Exterior_Ring(the_geom),
>     ST_Line_Locate_Point(ST_Exterior_Ring(the_geom), gps_pt)
> FROM ...
> Cheers,
> Kevin
> Doug Fischer wrote:
>> Is there some way to determine the closest point in the border of
>> the country to the point collected by the GPS in order to use the
>> distance_sphere() or distance_spheroid() functions for a more
>> precise measurement?
>> Thank you very much for any help.
> postgis-users mailing list
