[postgis-users] list of the closest borders
Kevin Neufeld kneufeld at refractions.net
Thu Sep 11 11:49:31 PDT 2008
Ok, yikes.  This is suddenly getting much more complicated than I
originally thought.
Yes, obviously the boundary approach does not take into account if the
point is inside a country polygon.
Also, the problem with your second attempt was that you were grabbing
only the first polygon out of a multipolygon and using that to test your
distances against.
This is a very quick hack that I'm sure you can clean up, but it may get
you closer to what you're after:
-- Sort and limit the final result
SELECT * FROM (
-- Filter out duplicate entries
SELECT DISTINCT ON (name) *
FROM (
-- Select the country we are inside
SELECT name, gmi_cntry, 0::double precision AS distance
FROM world_countries a
WHERE ST_Contains(
   a.the_geom,
   ST_GeomFromText('Point(-107.753906 48.400032)', srid(the_geom)))
UNION ALL
-- Select all countries and their respective distances
     distance_sphere(
         line_interpolate_point( a.geom, line_locate_point( a.geom,
b.pt) ),
         b.pt
     ) / 1609.344 AS distance
FROM (
   SELECT name, gmi_cntry, (ST_Dump(ST_Boundary(the_geom))).geom
   FROM world_countries ) AS a,
   (SELECT ST_GeomFromText('Point(-107.753906 48.400032)', 4326) AS pt) AS b
) AS foo
ORDER BY name, distance) AS foo
ORDER BY distance
LIMIT 5;
      name      | gmi_cntry |     distance
  United States | USA       |                0
  Canada        | CAN       | 41.4484753115909
  Mexico        | MEX       | 1148.15027501245
  Bahamas, The  | BHS       | 2165.10853394356
  Cuba          | CUB       | 2200.33855861009
(5 rows)
Cheers,
Kevin
Doug Fischer wrote:
> Kevin,
> I have played with these functions and created a query however it does
> not seem to be producing the correct results.
> What I have done is the following (just so you understand the data that
> I am working with).
> I have downloaded the World shapefile from
> http://www.cipotato.org/diva/data/MoreData.htm
> I used shp2pgsql to create the inserts for PostGIS into a table called
> world_countries with the following definition:
> gid - integer
> name - character varying(40)
> gmi_cntry - character varying(3)
> region - character varying(25)
> the_geom - geometry
> I selected a point close to the canadian border in Montana (lat:
> 48.400032 long: -107.753906) and ran the following queries
> 1)
> select name, gmi_cntry,
>     distance(the_geom,
>         GeomFromText('Point(-107.753906 48.400032)', srid(the_geom))) *
> 69.046767 as distance
>     from worl_countries order by distance limit 5;
> 2)
>     distance_sphere(
>             ExteriorRing(GeometryN(the_geom, 1)),
>             line_locate_point(
> srid(the_geom))
>     ) / 1609.344 as distance
>     from world_countries order by distance limit 5;
> Results of query 1:
> Canada            |    CAN    |    41.42...
> Mexico            |    MEX    |    1147.37...
> Guatemala        |    GTM    |    2408.14...
> Cuba            |    CUB    |    2413.21...
> Results of query 2:
> United States     |    USA    |    1277.33...
> Mexico            |    MEX    |    1336.31...
> Canada            |    CAN    |    1509.44...
> Cuba            |    CUB    |    2283.77...
> Guatemala        |    GTM    |    2313.55...
> As you can see from the results of the 2 queries, they are not even
> close.  I understand that the first query is not going to be all that
> accuate, but I tthought that the two would at least be in the same
> ballpark.  The results from query 1 are more like what I need, I was
> just trying to get a little more accurate.  Query 2 seems to be better
> when the Point that I am using in the query is not inside of a country
> already.
> Any ideas?  suggestions?  Anything would be appreciated.
> thank you very much,
> Doug
> On Sep 10, 2008, at 11:34 AM, Kevin Neufeld wrote:
>> Yes.  Experiment with
>> - ST_Line_Locate_Point(linestring, Point) - which returns a percentage
>> along the linestring the point occurs.
>> - ST_Line_Interpolate_Point(linestring, location) - which accepts a
>> "percentage along" and returns the interpolated point along the
>> linestring.
>> Since these functions accept a linestring, you could extract the
>> exterior ring of your country polygon.
>> Something like:
>> SELECT
>>     ST_Exterior_Ring(the_geom),
>>     ST_Line_Locate_Point(ST_Exterior_Ring(the_geom), gps_pt)
>> FROM ...
>> Cheers,
>> Kevin
>> Doug Fischer wrote:
>>> Is there some way to determine the closest point in the border of the
>>> country to the point collected by the GPS in order to use the
>>> distance_sphere() or distance_spheroid() functions for a more precise
>>> measurement?
>>> Thank you very much for any help.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
