[postgis-users] Buffer/Nautical Miles
Bruce Rindahl
rindahl at lrcwe.com
Thu Sep 11 14:32:06 PDT 2008
A nautical mile is 1 minute measured along a great circle on a sphere
(such as the equator or a longitude line). Thus your query will not
work- it will be too short in the x direction. If you are using UTM a
nautical mile is about 1852 meters.
Bruce
Blake Crosby wrote:
> I'm trying to create "circles" by using the buffer function around a
> point.
> The radius values i'm working with are in nautical miles. The
> definition of a nautical mile is 1 minute of 1 degree.
> Since this unit of measurement is based on a degree, and WSG84 is
> based on degrees of lat/long (and not meters like UTM) will the
> following be valid for a circle with a radius of 2 nautical miles
> around point (72.3,-45.3)?
> st_buffer(st_geomfromtext('POINT(-45.3 72.3)', 4326), 0.0166667*2)
> I'm trying to troubleshoot a problem I'm having and want to rule out
> any issues with my usage of buffer.
> Blake
> postgis-users mailing list
