[postgis-users] Buffer/Nautical Miles
Blake Crosby me at blakecrosby.com
Thu Sep 11 14:42:27 PDT 2008
Bruce,
Ok thanks.. that explains a lot. So really my only course of action is
to transform to UTM, do my buffer, then transform back to WGS84?
Blake
Bruce Rindahl wrote:
> A nautical mile is 1 minute measured along a great circle on a sphere
> (such as the equator or a longitude line).  Thus your query will not
> work- it will be too short in the x direction.  If you are using UTM a
> nautical mile is about 1852 meters.
> Bruce
> Blake Crosby wrote:
>> I'm trying to create "circles" by using the buffer function around a
>> point.
>> The radius values i'm working with are in nautical miles. The
>> definition of a nautical mile is 1 minute of 1 degree.
>> Since this unit of measurement is based on a degree, and WSG84 is
>> based on degrees of lat/long (and not meters like UTM) will the
>> following be valid for a circle with a radius of 2 nautical miles
>> around point (72.3,-45.3)?
>> st_buffer(st_geomfromtext('POINT(-45.3 72.3)', 4326), 0.0166667*2)
>> I'm trying to troubleshoot a problem I'm having and want to rule out
>> any issues with my usage of buffer.
>> Blake
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
