[postgis-users] st_coveredby query taking too much time
Balkan Uraz
balkan.uraz at gmail.com
Tue Sep 23 05:26:21 PDT 2008
Dear All;
I have been trying to process and update query (by st_coveredby) using 2
spatial tables. It seems that everything goes on track except that it has
been taking more than 2 hours right now.
All the related info is below:
max_connections = 300
shared_buffers = 256MB
work_mem = 2MB
maintenance_work_mem = 32MB
max_fsm_pages = 153600
wal_buffers = 1MB
checkpoint_segments = 16
effective_cache_size = 2GB
CPU: Quad Core Intel Xeon 2.33GHz
Memory: 4GB
balkan_20080908_0_0_1_postgis=# explain update yolorta_all set city =
(select iladi from iller where st_coveredby(yolorta_all.the_geom,
iller.the_geom) = 'TRUE');
QUERY PLAN
Seq Scan on yolorta_all (cost=0.00..3458534.64 rows=1526838 width=675)
SubPlan
-> Seq Scan on iller (cost=0.00..2.21 rows=1 width=7)
Filter: (($0 && the_geom) AND _st_coveredby($0, the_geom))
(4 rows)
balkan_20080908_0_0_1_postgis=# \d iller
Table "public.iller"
Column | Type | Modifiers
gid | integer | not null default
nextval('iller_gid_seq'::regclass)
plakano | integer |
iladi | character varying(15) |
ilceadi | character varying(20) |
the_geom | geometry |
Indexes:
"iller_pkey" PRIMARY KEY, btree (gid)
"iller_gid" UNIQUE, btree (gid) CLUSTER
"iller_the_geom_gist" gist (the_geom)
Check constraints:
"enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
"enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL)
"enforce_srid_the_geom" CHECK (srid(the_geom) = 4326)
balkan_20080908_0_0_1_postgis=# \d yolorta_all
Table "public.yolorta_all"
nextval('yolorta_all_gid_seq'::regclass)
adi | character varying(50) |
tipi | character varying(25) |
rnname | character varying(10) |
adiuluslar | character varying(5) |
kkno | character varying(25) |
city | character varying(50) |
country | character varying(50) |
district | character varying(50) |
subdistrict | character varying(50) |
Indexes:
"yolorta_all_pkey" PRIMARY KEY, btree (gid)
"yolorta_gid" UNIQUE, btree (gid) CLUSTER
"yolorta_all_the_geom_gist" gist (the_geom)
Check constraints:
'MULTILINESTRING'::text OR the_geom IS NULL)
Is this time spent for the query meaningful? What can I do for faster
spatial queries in this context?
Regards,
Balkan.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080923/f94ca7f5/attachment.html>
