[postgis-users] st_coveredby query taking too much time
Obe, Regina
robe.dnd at cityofboston.gov
Tue Sep 23 07:29:37 PDT 2008
Its probably more efficient to do
UPDATE yolorta_all
SET city = iller.iladi
FROM iller
WHERE st_coveredby(yolorta_all.the_geom,iller.the_geom) ;
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Balkan Uraz
Sent: Tuesday, September 23, 2008 8:26 AM
To: postgis-users at postgis.refractions.net
Cc: volkany at mobiliz.com.tr
Subject: [postgis-users] st_coveredby query taking too much time
Dear All;
I have been trying to process and update query (by st_coveredby) using 2
spatial tables. It seems that everything goes on track except that it
has been taking more than 2 hours right now.
All the related info is below:
max_connections = 300
shared_buffers = 256MB
work_mem = 2MB
maintenance_work_mem = 32MB
max_fsm_pages = 153600
wal_buffers = 1MB
checkpoint_segments = 16
effective_cache_size = 2GB
CPU: Quad Core Intel Xeon 2.33GHz
Memory: 4GB
balkan_20080908_0_0_1_postgis=# explain update yolorta_all set city =
(select iladi from iller where st_coveredby(yolorta_all.the_geom,
iller.the_geom) = 'TRUE');
QUERY PLAN
Seq Scan on yolorta_all (cost=0.00..3458534.64 rows=1526838 width=675)
SubPlan
-> Seq Scan on iller (cost=0.00..2.21 rows=1 width=7)
Filter: (($0 && the_geom) AND _st_coveredby($0, the_geom))
(4 rows)
balkan_20080908_0_0_1_postgis=# \d iller
Table "public.iller"
Column | Type | Modifiers
gid | integer | not null default
nextval('iller_gid_seq'::regclass)
plakano | integer |
iladi | character varying(15) |
ilceadi | character varying(20) |
the_geom | geometry |
Indexes:
"iller_pkey" PRIMARY KEY, btree (gid)
"iller_gid" UNIQUE, btree (gid) CLUSTER
"iller_the_geom_gist" gist (the_geom)
Check constraints:
"enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
"enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL)
"enforce_srid_the_geom" CHECK (srid(the_geom) = 4326)
balkan_20080908_0_0_1_postgis=# \d yolorta_all
Table "public.yolorta_all"
nextval('yolorta_all_gid_seq'::regclass)
adi | character varying(50) |
tipi | character varying(25) |
rnname | character varying(10) |
adiuluslar | character varying(5) |
kkno | character varying(25) |
city | character varying(50) |
country | character varying(50) |
district | character varying(50) |
subdistrict | character varying(50) |
Indexes:
"yolorta_all_pkey" PRIMARY KEY, btree (gid)
"yolorta_gid" UNIQUE, btree (gid) CLUSTER
"yolorta_all_the_geom_gist" gist (the_geom)
Check constraints:
'MULTILINESTRING'::text OR the_geom IS NULL)
Is this time spent for the query meaningful? What can I do for faster
spatial queries in this context?
Regards,
Balkan.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080923/067ac36f/attachment.html>
